1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 d16z6 really bad miss
Old Oct 24, 2009
z6coupe's Avatar
z6coupe is an unknown quantity at this point
Question 95 d16z6 really bad miss
i have a 95 civic coupe..d16z6 (1.6 vtec) it has developed a REALLY BAD miss..
i have changed plugs, wires, cap and button....checked fuel filter and pump and even checked to see if cat was plugged...nothing seems to help... it doesnt seem to miss at an idle but anything above 2000 rpm is horrible....any ideas...ill try anything!!
Old Oct 24, 2009
Re: 95 d16z6 really bad miss
what brand parts are you using? alot of times the cheapo parts do not work well, and certain brands of spark plug do not work at all. you should at the least have ngk/denso plugs and ngk wires. check the cylinder compressions too. and check the fuel pressure. your injectors may also be clogged and not spraying fuel properly.
Old Dec 20, 2009
civtegra's Avatar
civtegra is an unknown quantity at this point
yea that definatly sounds like it could be compression miss, does it do it worse when your going uphill?
tock172
Jul 21, 2015 06:25 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
Vanman
Jun 9, 2015 08:17 PM
Ninetyatecivic
May 9, 2015 07:48 PM
usajags84
Apr 10, 2015 09:54 PM
