1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Hey guys, brake lights out. Bulbs and fuse both good. Switch disengages... And what..
Old Oct 13, 2009
chriswf's Avatar
chriswf is an unknown quantity at this point
I have a 91 civic wagon. Brake lights aren't coming on. The rear night time lights come on... But when I push the pedal I'm not getting a brake light.
ALL fuses are good and intact. Bulbs are good, right size/filament.
When I push the brake in, the switch piece slides out...
BUT, there's a blue and red wire, that connects to that "3M" adapter. Both ends on each side of that 3M adapter are cut. The green wire (that runs from the brake switch) is still intact.
Is the red and blue important? I can't see where either side runs so I'm unsure of what it does...
Any tips on what to trouble shoot next would rock!
Thanks guys.
Edit: Here's that wire btw...
Old Oct 14, 2009
CraigW's Avatar
Re: Hey guys, brake lights out. Bulbs and fuse both good. Switch disengages... And wh
The white part ?? It looks like a wire tap to me, used to tie a new wire into an exsisting wire. It was likely someones mod or for an alarm.
Does your horn work ?? They usually share a fuse, If it does work I would start by checking for voltage on the 2 wires going to the switch. 1 side should have constant voltage and the other side should have it when the pedal is pushed down.
Old Oct 14, 2009
chriswf's Avatar
Found out the fuse under the hood was blown.
Horn still doesn't work. When I push the button everything on the car dims. I assume the horn(s) are bad. Don't know if I care at all about a horn at the moment...
But thanks much for the help!
zack22490
Apr 29, 2015 03:17 PM
Rinzlor
Apr 24, 2015 10:33 AM
Fastfebur
Apr 22, 2015 01:37 PM
shaejb15
Apr 12, 2015 11:38 AM
JDog2001CivicEX
Nov 2, 2001 02:27 PM
