ARE THESE THE BULBS I NEED!??
OK SORRY TO BOTHER YOU AGAIN BUT ARE THESE THE BULBS I NEED FOR MY CORNER TURN SIGNALS? AND ARE THEY THAT MUCH, MONEY ISNT AN ISSUE BUT I DIDNT KNOW IF THEY WERE JUST PRICED HIGH ON THERE OR NOT
LED
THANKS
P.S. WHEN U HAVE UR LIGHTS ON THEY LIGHT UP AND THEN WHEN U TURN UR SIGNAL THEY JUST BLINK? I MEAN ITS NOT LIKE REGULAR BULBS THAT ARE DIM AND THEN LIGHT UP BRIGHTER WHEN THE SIGNAL IS TURNED ON, RIGHT?
LED
THANKS
I'm pretty sure that they will not work.
7443's is what you need
7443's are double fillament (one for on, on for blink)
7440's are single fillament (one for blink)
so those will not work if you want them to blink and come on.
well not unless you rewire the plug that the bulbs plug into.
if you really want those bulbs and you want them to blink as well as come on with your lights
what you have to do is take the red and green wire that come into the connector and wire them together.
I hope this helps
-Lowtek
I hope this helps
-Lowtek
Retired - SoCal FI Mod
i'm pretty sure those are the bulb you are looking for.... i bought ones very similar to those... looks right.. check the manual and do a search if you have to... i would do it for you but i'm really lazy right now with the end of spring break coming up...
I bought the 7443 Xtreme from PIAA and they work all right but those would be unique, I think you need the 7443 because I don't think 7440 would work since it has only one fillament. Unless yeah you wanna re wire.
cferry7
Oct 18, 2015 06:32 PM
shaejb15
Sep 12, 2015 01:02 AM
MamaBear2015
Sep 4, 2015 09:04 PM
mac25
Aug 21, 2015 11:14 PM
