Turbo help?
Old Sep 11, 2009
mmajimmy19's Avatar
mmajimmy19 is an unknown quantity at this point
Turbo help?
Sorry im new to this. i searched but couldnt find my answer. Is a good idea to put a turbo into a 2002 honda civic lx auto with 150k miles. Im sorry im learning as we speak.
Old Sep 11, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: Turbo help?
Very general question...Its a good idea if you know what you are doing and want more power. Horrible idea if you dont want to spend ALOT of money and dont know anything about motors or how a turbo system works. Keep searching, tons of info on this site...
Old Sep 12, 2009
seoul4korea's Avatar
seoul4korea can only hope to improve
Re: Turbo help?
By alot of money he means ALOT. Its a Very bad idea to but turbo pressure on a motor with that many miles. Your going to start blowing seals and your head gasket. I would look into rebuilding your motor first then forced induction. Do you know how a turbo charger works?
Old Sep 12, 2009
greeen01civic4d's Avatar
Re: Turbo help?
its a great idea, ull make 300 hp on 4 psi and get 40 mpg with stock ecu, fuel pump and injectors
Old Sep 12, 2009
Re: Turbo help?
You need to have a foundation to build off of. Boost a motor with that many miles is NOT a good idea at all. Sure you'll get 300 HP for about a month and then you'll start running into the nightmares that come with it. Turbo charging requires of planning and understanding before attempting. The goal of any project turbo charging should be Reliable power. it's easy to tell some one to turbo your project, but with out preparing your project car it's going to be hell later on. Many problems could be Running a lean condition, Knock, Miss fires, as stated before Blown head gaskets or seals. yes you do have OBD-II but tuning should not just consist of ECU flashes. Proper tuning and monitoring systems should be used.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
