Just bought my first car: 98 H Civic EX
Old Aug 7, 2009
nixhex's Avatar
nixhex is an unknown quantity at this point
Talking Just bought my first car: 98 H Civic EX
113,000 miles on it when I got it about a week ago for $4800
Carmax certified 1 owner with clean history, new muffler, one fender bender.
Turns out an MIT Professor had traded it in (we found his card in the glovebox)
VERY minor dings and scratches, no rust damage, no trunk water damage, everything on it works perfectly. Stock EVERYTHING in and out.
Replacing the water pump, timing belt, doing the tranny fluid drain/replace.
Thoughts or suggestions on maintenance?
Old Aug 7, 2009
fracas's Avatar
fracas is an unknown quantity at this point
Re: Just bought my first car: 98 H Civic EX
You have every thing covered minus the Plugs, Cap Rotor, Wires, Tires and check all lights. Other than that you should be good.
Old Aug 7, 2009
nixhex's Avatar
forgot to mention it has brand new tires on it. And I'll check the spark plug wires later today!
Old Aug 7, 2009
fracas's Avatar
Forgot to add. Check Tie Rods, Wheel Bearings, Brake Pads and Axles.
Old Aug 9, 2009
bluetwo's Avatar
bluetwo is an unknown quantity at this point
.....you might need to change the fuel filter?
I can't think of anything else really. It seems like you guys have it pretty well covered.
Old Aug 9, 2009
sql_civic's Avatar
oil, oil filter, air filter, inspect brakes, PCV valve, maybe clean the injectors and do a wheel alignment
Old Aug 11, 2009
ilikesnackpacks's Avatar
ilikesnackpacks is an unknown quantity at this point
Nice Civic...I'd throw some tint on the windows man, it'll look great with silver!
mistermenphis22
Apr 3, 2016 08:06 AM
tylerginevan
Apr 27, 2015 12:29 PM
TheRubixHorse
Apr 17, 2015 08:55 AM
Thees1
Apr 14, 2015 08:23 AM
lilbluecivic
Nov 7, 2001 06:49 PM
