Dash Wiring Help
Old Aug 12, 2009
Zachs96civic's Avatar
Zachs96civic is an unknown quantity at this point
Dash Wiring Help
I need some help. I bought a 1996 Civic for my son. The guy I bought it from put a 2000 civic dash in it. I need a wiring diagram to hook up the A/C - heater controls. I found the diagram for the 1996. I need the wiring diagram for the 2000. Wiring harness # 32257-S04-A101.
Old Aug 12, 2009
unTuned's Avatar
Re: Dash Wiring Help
so he changed the dash and didnt hook up heat or ac ever? or did they break?
a bit more info on what exactly youre doing might help. there could be an alternative to the harness youre using.
Old Aug 12, 2009
ilikesnackpacks's Avatar
ilikesnackpacks is an unknown quantity at this point
It's probably going to be much easier and much much more cost efficient to buy a 96-98 climate control center console and switch it out if you still have plugs.
Old Aug 12, 2009
The guy put a 2000 dash in a 1996. He didnt hook up the a/c, heater, rear defroster - center console area. The emergency flasher plug fits, The guy cut the plugs off the 1996 side. The only thing I can think to do now is get a wiring diagram for a 2000, cut and splice the wires together.
I found a wiring diagram for the 1996 civic online. I cant find a 2000 civic diagram.
I need to know which wire goes to what. The wiring harness that is plugged in the back of the 2000 center console is part #32257-S04-A101.
Can anyone help ?
Old Aug 12, 2009
Can anyone help ?
IIRC the 96 dash and 00 dash are the same, except for the climate controls. You should be able to get on ebay or go to a junk yard and get the climate control/dash bezel for the center and swap them out. There's much much more involved in the climate control swap (do a quick search to find that out) then just rewiring the controls. Do yourself a favor and spend a little money on the 96-98 climate controls and rewire those into original harnesses.
Check out this link - may be helpful.
http://www.honda-tech.com/showthread.php?t=605432
BootyDo
Jun 21, 2016 03:45 PM
JUNITO
Jul 9, 2015 08:36 PM
aultman1990
Jul 9, 2015 08:27 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
