Leaky valves?
Old Jul 8, 2009
levyfamily3's Avatar
levyfamily3 is an unknown quantity at this point
Leaky valves?
Need to know if I need to replace valve seals. Engine is 2000 civic si b16 doch. Few misfires, straight pipe no cat. Blueish, grey smoke when I downshift and when I come to a complete stop.
Old Jul 8, 2009
Re: Leaky valves?
yes if you are burning oil
Old Jul 9, 2009
sql_civic's Avatar
Re: Leaky valves?
You could be burning oil from bad oil rings.
Old Jul 20, 2009
JREJ8's Avatar
JREJ8 is an unknown quantity at this point
Re: Leaky valves?
compression test it. if the test reads low cylinder pressure then pour alittle oil into the cylinder though the spark plug hole and retest. if the pressure rises then you have bad piston rings and you need a rebuild. if not then you have bad valve seals or a bent valve or something in the head wrong.
Old Jul 20, 2009
JREJ8's Avatar
Re: Leaky valves?
but yes you are burning oil for sure:
blueish smoke: burning oil
black smoke: running rich
white smoke: Burning coolant/water.
Old Jul 20, 2009
denice25's Avatar
Member
denice25 will become famous soon enough
Re: Leaky valves?
replace it when they have leaks... or try to compression test first...
Old Jul 20, 2009
TRIZ's Avatar
Re: Leaky valves?
I think I have a head gasket rebuild kit for a B18. I could double check it your interested. It has everything, head gasket, valve seals, every other kinda seal, etc. I bought it on accident when looking for a D series one. Its unopened.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
BJB
Sep 14, 2015 11:16 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
