Hissing/Grinding Noise
Old Jul 6, 2009
Hybridia's Avatar
Hybridia is an unknown quantity at this point
Has anyone experienced hissing/grinding noise when accelerating and stops or mediates when break pad is being pressed? Mine (01 LX) started to make the noise... break issue? OR something bigger?!
Thanks y'll
Old Jul 7, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: Hissing/Grinding Noise
change the brake pads. thats what it sounds like. the grinding noise is probably because the brake pad is down to the metal already. so you probably damaged your rotors too. you can get the rotors resurfaced for cheap if they arent damaged badly. or you might have to get new rotors. you need to get new brake pads though. check your brake pads to see if you have any more meat on them.
Old Jul 7, 2009
bigworm's Avatar
bigworm is an unknown quantity at this point
dude, I had the same problem with my EM2, changed rotors and pads, nothing worked. You got to change hub bearing and all the parts as below - this will help 100%:
01463S04V00 - 2 pcs
45235S0A003 - 1 pcs
45262S0A003 - 1 pcs
44300S5A008 - 1 pcs
Old Jul 7, 2009
^^ he could be right as well. check the brakes first though. wheel bearing at autozone costs around 40 bucks.
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
