P1456
Old Jul 2, 2009
devolic's Avatar
devolic is an unknown quantity at this point
P1456
Hello I have a 2005 Civic DX the check engine light came on. It came out to be a P1456. I tightened the fuel cap what else would cause this code?
Old Jul 3, 2009
Re: P1456
well usually youre supposed to replace the fuel cap with a new one, cause it still has the pressure seal inside that could just be worn out. get a new oem honda cap first and try that. if that doesnt fix it, youre gonna have a hard time finding where the leak is. the evap recovery system is huge and there are alot of lines that could have a small leak. this is the actual code: sounds like a new gas cap will fix it tho.
P1456 EVAP Emission Control System Leak Detected (Fuel Tank System)
Old Jul 4, 2009
MidnightCivic's Avatar
Re: P1456
How far did you drive after tightening the fuel cap?
Old Jul 4, 2009
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
Re: P1456
was the cap loose at all. most likely just re tighten the cap clear the code and be on your way. i see them come into the shop all the time. especially if the cap was loose from the gas station guy.... if you re tightened it and cleared the code and it comes back on with the same code then you have a real evap problem, in that case it does get complicated. good luck let us know if it comes back on. but well all hope that it doesnt.
kittykate83
Jun 21, 2019 12:24 PM
mrohitredd
Jan 23, 2015 11:10 PM
jeremyhurst02
Jun 2, 2011 11:34 AM
02civicg5
Oct 1, 2009 12:22 AM
Island2K2
Apr 21, 2006 12:34 PM
