Cel p1298 & p1456
Old Jun 2, 2011
jeremyhurst02's Avatar
Newb
jeremyhurst02 is an unknown quantity at this point
Cel p1298 & p1456
This is for a 2002 Honda Civic LX, Manual Tranny.
The other day my CEL came on, and I got two codes in this order:
P1456 EVAP leak
P1298 Electric load detector high
I was told by my mechanic that it is probably just a loose gas cap, so we fixed it and cleared the code.
About 40 miles of driving later, it came right back on with the same two codes.
I've seen numerous posts about the P1456 saying its a loose gas cap and that it'll go away on its own once you've tightened it, and that isn't happening for me.
I've seen a few posts on the P1298 issue saying to just replace the whole ELD in the under-hood fusebox, but I'm concerned about the two showing up together.
Are they related? I feel like they almost have to be.
Any help would be greatly appreciated, thank you.
Old Jun 2, 2011
lazlong's Avatar
Re: Cel p1298 & p1456
You'd be surprised what changing the ELD will erase. Regardless you need to change it.
For the P1456 there are 5 pages of diagnosis, I am way to lazy to type all that. Especially when you can download it here: https://www.civicforums.com/forums/1...e-updated.html
Old Jun 2, 2011
Newb
Thanks for the input, since I see that the ELD is relatively cheap, I'll have it replaced and see what happens. I'll keep you updated.
Old Jun 2, 2011
lazlong's Avatar
ELD: P/N 38255-S5A-003. If you just ask them for the ELD they will try to sell you the entire fusebox ($250). You have to ask for it by part number. Good luck and post back results.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
