Help
Old Jun 25, 2009
2006 honda coup's Avatar
2006 honda coup is an unknown quantity at this point
Help
Hello. I purchased a 2006 Civic Coupe 14 days ago from a dealer. The oil indicator came on last night (15%). I ended up adding 4 quarts of oil to get it back to full. Is the engine toast? It seems fine and the oil is not leaking out. I do like the car - it looks like the dealer drained the oil and forgot to refill -- is this possible? I have about 1000 miles on the car since I purchased it 14 days ago -- thks for your input
Old Jun 25, 2009
04 Honda Civic's Avatar
Re: Help
I would probably bringing that car back to the service center and tell them what happened. If your oil was that low you probably have shortened the life of that motor dramatically
Old Jun 25, 2009
CraigW's Avatar
Re: Help
Did you check the level on the dipstick before adding ??
The indicator inside is the life not the level.
And yes, if it did indeed take 4 quarts you need to get back in touch with the seller.
Old Jun 26, 2009
TRIZ's Avatar
Re: Help
Hmm.... where did you add the oil?
