NEED axle help!!!
NEED axle help!!!
93 EG with a B18B1 and a GSR tranny. Replaced the axle and after I first put it in I turned it on and in neutral when I let off the clutch it was grinding. So I took it out and checked it put it back in made sure it was in there, splines lined up, all that stuff. Spun the other side wheel when I turned it. I turned it on again and it didn't grind when I let off the clutch in neutral, put it in gear and start letting off the clutch and it starts grinding. It has to be in there tight, I shoved it in as far as I could and gave it a few good smacks with a rubber mallet. I still feel it jiggling though. It is the right axle, we matched up the old and new at the auto parts store.
Sep 26, 2023 06:44 PM
beanhead
Sep 24, 2015 12:04 PM
califcamper
Jul 21, 2015 10:34 PM
