HID TYC Wiring Problem...No power??
Old May 5, 2009
nick82006's Avatar
nick82006 is an unknown quantity at this point
Ok so i bought a set of eBay HID 6000K H1 and i will be putting them in some TYC projectors. I have an 01 2dr LX. So before i put them in i want to make sure they work correct? So to test them i hooked them up like this.
I did this with the 2 bulbs i have and i have 3 ballast(all same).....I tried the first 2 i received and they didnt work, i requested a working pair, and they sent me one that was Supposed to work. I cant help but think its the way i am wiring them or there is some small detail i am missing..... I have a relay as well and looked over Gearbox's diagram. I wired all the first 2 correctly(i think) and they did not come on. I am trying to simplify the wiring so i can actually see if they work.
ANy input on why this would not light the bulbs up? and "Cause its from ebay" is not a good answer, its basically all the same ****. 60 bucks or 250)
Old May 5, 2009
Re: HID TYC Wiring Problem...No power??
im assuming the + and - in the drawing are the battery terminals. if so, they should light up no problem so long as the bulbs are good. i never had issues with my first and only pair of "yourhid" ballasts off ebay. and they were only $100 for the kit.
Old May 5, 2009
mdawg's Avatar
mdawg is on a distinguished road
Funny question but you have popped the fuse out to see if its good right? I have the set from "yourhid" and they worked fine for me.
Old May 5, 2009
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Can't you just apply the + and - directly to the battery? I mean it shouldn't blow it b/c everything in the car draws from the battery and then you can work from there to figure out if it is the ballast, bulb, or your wiring. Good luck and get some pictures of the final product.
Old May 6, 2009
electric130's Avatar
if you go straight to the battery, they should work. if you're connecting to the headlight connector without a harness, then stop, buy a harness and try again. you need a relay harness. if you have a harness, then make sure it's for a ground switched H4 system. if it's a positive switched, it won't work with our cars.
Old May 6, 2009
LT2004ever's Avatar
I wil fix vBPlaza today
danget... everyone beat me to it
Old May 7, 2009
lmao someone has to finish last. But atleast u wouldn't tell him to attach it to the cig light to try lmao.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Brianmc1995
Jun 4, 2015 07:51 PM
darwin-t
Apr 18, 2015 09:29 PM
Dmitri
123
Oct 13, 2005 08:01 PM
Mary
Jan 2, 2002 06:42 AM
