1995 Honda Civic losing oil ?
Old May 1, 2009
ivy7845's Avatar
ivy7845 is an unknown quantity at this point
Just bought a 1995 Honda Civic CX, did an oil change right away and it’s already down a quart after about 250 miles.
The car runs great but pushes a bit of white smoke every once in a while and the exhaust smells a bit rich rich of oil (on and off).
It doesn’t seem to be losing any power and doesn’t push smoke in higher RPMs or at any specific time. Can see a bit of dark dirty oil pool up on the front underside of the engine but doesn’t seem to be dripping when parked or at idle.
Haven’t seen it drop oil anywhere but somehow it seems to be getting into the exhaust once in a while. Not leaking from the oil plug and can’t see exactly where it’s coming from. The car apparently sat for a year and a half before being driven 150 miles to the city I bought it in and the 16V motor was rebuilt in 2006 about 65,000 miles ago.
Everything is great but the oil consumption and occasional and brief blasts of white smoke. Any ideas what the problem could be?
Old May 1, 2009
lowlife9's Avatar
Re: 1995 Honda Civic losing oil ?
put a thicker oil in it .
Old May 1, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
sounds like a headgasket. check your coolant and see if it has oil mixed with it. if there is oil then most likely its a headgasket. but just because there is no oil in the coolant doesnt mean it isnt a headgasket. your rings/seals could be wearing out as well. do a compression test to see if everything is up to par. if the compression test is fine its probably one of the crank seals that are going bad. if you live in an average weather area (where its not too cold) i would say use synthetic 5w30 oil as well. what oil do you use? if your using dino oil the oil could be blocking/clogging the seals preventing you to see if the seals are bad or not.
Old May 18, 2009
autome5's Avatar
autome5 is an unknown quantity at this point
Drive it for a while keeping a close check on oil usage like 3000 miles if it continues to use a quart that frequently find a real good shop one you fill will look out for you like free advice, and ask them what they thank?Maybe even get a leak down test to pin point were the oil is going. Some times the results are not the greatest news, but at least you will know wich direction to take, thicker oil only may solve the problem for a little bit.
Old May 19, 2009
bigaudiofanatic's Avatar
bigaudiofanatic is an unknown quantity at this point
Ours lost oil of cores it had 298,000 miles on it as well. We just kept adding oil to it every few weeks. Also might be head gasket check your coolant.
Old Jul 1, 2009
daddyforty's Avatar
daddyforty is an unknown quantity at this point
Have you changed your spark plugs lately? If not pull one out and check if the chamber is full of oil. I have the same problem. Last time I changed my spark plugs 3 out of four spark plugs were coated with oil.
Old Jul 1, 2009
daddyforty's Avatar
Old Jul 1, 2009
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
i have the same problem but i think it has something to do with the PCV valve, the valve guides or check the valve cover gasket. I had an issue in which I didn't change the spark plug tube seals and some oil got into the spark plug chamber and would cause problems.
Runner88
Mar 2, 2023 04:54 PM
LionSpratt
Jan 29, 2017 11:07 PM
beneditti
Jan 15, 2016 12:31 PM
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
