leaking oil from block found spot need advice
Old Apr 30, 2009
breaker110's Avatar
breaker110 is an unknown quantity at this point
front left bumper collision pushed headlight under front frame, since then it has been re-bent as close to normal as possible, but I thought I was leaking oil and I was and I found what I believe to be the culprit.
ID:	76378   Click image for larger version
ID:	76379   Click image for larger version
ID:	76380   Click image for larger version
Old Apr 30, 2009
Re: leaking oil from block found spot need advice
i cant see it. is it comng from the valve cover?
Old Apr 30, 2009
greeen01civic4d's Avatar
there is no leak where ur pointing..... look for a clean spot amongst dirty, that will tell u where the leak is
Old Apr 30, 2009
04 Honda Civic's Avatar
u showing us pictures of the valve cover, but I really dont see any oil..clean it up with some engine bright or something and see if it comes back
Old May 2, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
honestly it just looks like your engine is dirty. i dont think that is an oil leak.
Old May 5, 2009
breaker110's Avatar
it was making small puddles after a recent oil change then stopped, and a couple mechanics have mentioned they think I am leaking oil, I looked closer at it, and noticed it sounds a little rough and it was leaking a little, I thought it was a cracked pan from the collision, my buddy kept pointing to this spot i pictured..... doesnt speak very good english... I think he was talking about the head gasket he said I should take the valve cover off and replace a seal (gasket)??/
welllll anyway to know for sure before i get dirty?
Old May 5, 2009
amexicancarguy's Avatar
amexicancarguy is a glorious beacon of lightamexicancarguy is a glorious beacon of lightamexicancarguy is a glorious beacon of lightamexicancarguy is a glorious beacon of lightamexicancarguy is a glorious beacon of light
after an oil change? it could just be the extra oil on the block from the change. The position of our oil filters make a mess when we change them. It could just have been that. The mechanics probably just wanted to make more money. if you really do have a leak i dont see it. good luck
Old May 5, 2009
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
i dont see anything
Old May 5, 2009
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
I'm not seeing anyone either, but if you're sure that it's coming out along the base of the valve cover, then a new VC gasket should fix that right up!
Old May 5, 2009
is it dripping down on the ground? it could be coming from the drain bolt, if you forgot to put a washer or a washer thats too thin. or even the valve cover but it would be liquid oil not just dried black stuff.
Old May 5, 2009
Clean your motor and undercarriage its the only way to find out unless u want to go out and buy some dyes
Old May 9, 2009
breaker110's Avatar
more pictures, i was thinking it was the gasket head/ if you look at the pics there is a little damage on that corner and a piece of pant chip.
ID:	76475   Click image for larger version
ID:	76476   Click image for larger version
ID:	76477   Click image for larger version
Old May 9, 2009
breaker110's Avatar
haha the last 2 kind of suck there sideways
Old May 9, 2009
breaker110's Avatar
damit ill take some more tomm and use paint to highlight what im trying to convey
Old May 10, 2009
having some crusty oil is normal. there is always a lil seepage around the engine seals and valve cover. unless you have liquid oil dripping in good amounts, id say you are okay. use degreaser to clean what is there and see if it comes back.
Old May 10, 2009
bakertime's Avatar
Yeah, that doesn't look like a steady leak that you should be worried about. Something like that can even be some spilled oil after an oil change that made it's way down there. Like gearbox said, clean it and see if it comes back.
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
Jigee
May 9, 2015 11:18 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
Grey
16
Jan 27, 2002 11:34 PM
