Engine mounts failing
Old Mar 31, 2009
sebdiz's Avatar
sebdiz is an unknown quantity at this point
Exclamation Engine mounts failing
I drive a 93 Civic Lx.. its a auto, well ive had the car for quite a while and i can feel that the hood(engine and i think the muffler) and all vibrating, especially when im driving and im on the brake(red light).. it sometimes sounds like someone rattling a cage.. its gotten pretty bad.. i know my drivers side mount the one that u can see from the wheel is bad.. the rubber part has broken.. well short story shorter... took it to a shop.. $800 to replace all mounts and labor to put them in... i know its a ripoff so deff not going that route.. thinking of a cheaper route.. a friend of mine who works on my car from time to time tells me to just replace the inserts with ***athene inserts.. lol i forgot the name.. he told me i could just replace all the inserts and i should be good..
well the first question.. is he right? can we just replace the inserts.. bushings i think he said.. im very new to this subject.. mounts and yeah.. and it will be good? or would i still have to replace the mounts? or mount..
If i can just buy the inserts.. do you guys know where i can get them? and approximately a price to look at..
Thanks you guys!. in advance.. you know.
Old Mar 31, 2009
04 Honda Civic's Avatar
Re: Engine mounts failing
If they are like the ones on the 7th gens you cannot replace the inserts you have to replace the whole mounts.. They are about $100 each for the two sides and about $25 each for the front and the rear. I am in the process of doing mine on my 2004 civic since one of them broke and another is in suspicion. They are fairly easy to change just need to be careful and use a jack and a piece of wood underneath the oil pan.
Old Mar 31, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
just replace the mounts they are not that expensive the reason the shop is asking $800 is cause they half to pull the motor to replace the mounts you might be able to get inserts that go around the mounts but the mounts still have to be replaced If you are the die hard racer type you can fill the mounts with 3M window weld and make your mounts essentially solid mounts but your car will vibrate like ****
Old Mar 31, 2009
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
3m window weld and fill them up
Old Apr 1, 2009
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Honestly, motor mounts are very easy to do and if your buddy feels confident enough to do them, have him do it. as for the inserts, I've only heard of mounts being made that way, not so you could swap out inserts.
Old Apr 1, 2009
sebdiz's Avatar
ok so with what u guys are saying that regardless im gonna have to replace my mounts..? Im not the diehard racer.. do like the performance but i want the car to feel good and not vibrate as much as it it... i have no idea what you guys mean by 3M window weld them?
By what my friend is telling me it sounds tat he wants me to buy something like this..
http://cgi.ebay.com/ebaymotors/Motor...Q5fAccessories
I want to know if i should spend my money on these? he tells me they should work... or just buy new mounts. thanks for your help!!.
Old Apr 1, 2009
why not buy the new mounts they are around 100 bux
Old Apr 2, 2009
"These Inserts go in and around the rubber of your stock motor mounts," according to the auction. According to the information about the mounts you have already, these will only act as a band aid if anything at all. I would highly recommend the new mounts. You can buy them new or find a junkyard civic with the mounts. Plus the auction is only for 5 speeds anyways so they may not even fit.
Old Apr 2, 2009
bomerman19's Avatar
the 3m window weld trick is were you pull out your motor mounts and you fill them with 3m window weld let them dry and now you basically have solid motor mounts the will not flex and can be a very harsh ride it will help you put power down to the ground though. I suggest this if you are tracking your car if it is a daily driver don't do it.
Old Apr 4, 2009
sebdiz's Avatar
Appreciate the feedback.... yeah im thinking of buying mounts..replace them all or the failing ones? annnd hondautomativeparts best place to get them?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
mikemc422
Aug 9, 2018 05:41 PM
bsmiley
Apr 27, 2015 01:27 PM
streetglower123
Apr 12, 2015 10:56 AM
