'02 Civic LX - Screeching noise while starting cold
Old Mar 21, 2009
Fabian-'s Avatar
Fabian- is an unknown quantity at this point
Unhappy '02 Civic LX - Screeching noise while starting cold
Hello all,
I've noticed that lately my 2002 Civic LX is making a short (1 second or so) screeching noise when it starts out cold, it doesn't happen as I'm turning the key but right after it starts.
Once it warms up I can turn it off, start it back up and it won't happen again. Any ideas? Maybe one of the belts?
Thanks in advance ,
Fabian.
Old Mar 21, 2009
popee's Avatar
popee will become famous soon enough
Re: '02 Civic LX - Screeching noise while starting cold
might be your alternator belt gotta re-adjust it, had the same problem
Old Mar 22, 2009
phil6006's Avatar
phil6006 is an unknown quantity at this point
It could be any belt basically. You need to check the deflection of each belt. The power steering and alternator is usually the most common, but theres about 3 or 4 others.
If you press on it with your finger and it only goes down about 1/8-1/4" with moderate force, then you should be ok. Of course the best way to check is to get the right tools and cross reference the book.
When was the last time you did a tune up? If it has been a while, I would just replace all the belts, especially if any are starting to look worn.
Old Mar 22, 2009
EM24's Avatar
EM24 is an unknown quantity at this point
yeah thats ur belt bro
Old Mar 22, 2009
usually the alternator belt gets loose.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
Linda0818
Apr 23, 2015 11:30 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
