what i should change for my car maintence civic lx 02
I am wondering what i should do or maintence for my civic lx 02 70k miles and i don't want to *** it up because of some dumb aftermarket item but i already change:
Air Filters
spark plug
coolant drain and replace
Air Filters
spark plug
Re: what i should change for my car maintence civic lx 02
you change ur sparks at 60k yes.
you change ur intake air filter 10-15k miles. so if u are getting close to the 15k, then do it.
coolant change is a good idea too.
flush ur brake lines (bleed them untill new fluid is fully in ur system)
change ur ATF or MTF @ 60k is a good idea too but not needed. (i would though)
check ur brake pads
check ur CV boot.
check ur brake pads
check ur CV boot.
ok i just changed my air filter recently so i should change it around 80k and i also did my brakes but for transmission fluid should i do a flush or just drain it and replace new fluid in to the engine!?
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
