what i should change for my car maintence civic lx 02
Old Mar 11, 2009
XAkatsuk1X's Avatar
XAkatsuk1X is an unknown quantity at this point
Smile what i should change for my car maintence civic lx 02
I am wondering what i should do or maintence for my civic lx 02 70k miles and i don't want to *** it up because of some dumb aftermarket item but i already change:
Air Filters
spark plug
coolant drain and replace
Old Mar 11, 2009
civicfan1203's Avatar
Look at me im a supporting member
civicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nice
Re: what i should change for my car maintence civic lx 02
Look in the back of your owners manual. I'm not to sure what all you gotta do or i would tell you though.
Old Mar 11, 2009
sl33pyriceboi's Avatar
you change ur sparks at 60k yes.
you change ur intake air filter 10-15k miles. so if u are getting close to the 15k, then do it.
coolant change is a good idea too.
flush ur brake lines (bleed them untill new fluid is fully in ur system)
change ur ATF or MTF @ 60k is a good idea too but not needed. (i would though)
check ur brake pads
check ur CV boot.
Old Mar 12, 2009
XAkatsuk1X's Avatar
ok i just changed my air filter recently so i should change it around 80k and i also did my brakes but for transmission fluid should i do a flush or just drain it and replace new fluid in to the engine!?
Old Mar 12, 2009
kcari's Avatar
spark plugs at 75K?
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
