97 civic auto tranny problem
Old Mar 2, 2009
chris694205's Avatar
chris694205 is an unknown quantity at this point
hello guys i recently purchased a 1997 civic EX with a 1.6 litre vtec and auto trans for a gas saver... i did an engine swap and the thing runs pretty decent now... but my D4 light is blinking?? from what i understand it is like a service trans soon light or something.... anyone have any ideas what that could be
Old Mar 3, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: 97 civic auto tranny problem
Yes, it is a trouble code with the transmission. Did you leave any connectors loose? Otherwise you'll have to let us know what the code number is.
Old Mar 4, 2009
shadymechanic's Avatar
shadymechanic is an unknown quantity at this point
Check for any loose or cracked electrical tranny connections, first. Make sure all hydraulic lines are installed properly- nothing reversed. Check fluid level - make sure you are using Honda fluid not a knock off. You might have to reset the light- is all.
Look for the obvious because that's usually what it is on civics.
Old Mar 4, 2009
ScottDR's Avatar
Totally agree with shady...it's almost always something simple.
Old Mar 4, 2009
this damn car has given me so many problems... the codes are p0700 and p1758... the transmission seems to shift fine for a honda but i dont think the torque converter is locking???
Old Mar 4, 2009
ScottDR's Avatar
Ok, yes those codes indicate 'lock up clutch does not engage'. Possible causes (just as we stated-loose wires): A) Disconnected lock-up control solenoid valve B connnector, B) Short or open in lock-up control solenoid valve B wire, or C) Faulty lock-up control solenoid valve B.
I can't really type the instructions on how to track it down (it has diagrams). I can almost guaranty any problems you are having are due to loose/corroded connectors to the transmission/transmission ECU.
Old Mar 5, 2009
now this selenoid is located on the passenger side of the tranny on the top correct??
Old Mar 6, 2009
ScottDR's Avatar
It's on top, yes. The 2pin connector is right there. Measure resistance between both terminals and body ground. This should be 14-25ohms. If that's within spec, the solenoid is fine. I'm still guessing connection somewhere.
Old Mar 13, 2009
well i dont have the the meter to measure that... but all the connections look fine so im figuring the stupid selenoid is bad? anyone know where to get one
Old Mar 13, 2009
ScottDR's Avatar
Just out of curiousity, did you unplug and replug it a few times? If so, do an ECU reset procedure and see if you still have the codes. That might fix the problem. If not you can get a solenoid at a local dealer or on-line. There are several Honda dealerships that sell the parts on-line, but know that shipping and handling can sometimes make or break the cost savings difference. Not sure but some auto parts stores may also carry them *shrug*.
PS there is also a shift solenoid filter that is sandwiched between the solenoids and the transmission housing. I'd even try replacing that before buying a solenoid!
Old Mar 23, 2009
yes i did unplug it a few times.... even took it out and looked it over and it seems fine...
Old Mar 25, 2009
well the starter quit working... so i changed the starter and the D4 light stopped blinking.... i have no idea how or why but that was the fix to it
Old Mar 27, 2009
go figure
usajags84
May 10, 2015 08:11 AM
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
dooner24
Apr 14, 2015 07:51 PM
viper775
Nov 8, 2001 09:14 PM
