Evap Canister Location?
Old Feb 28, 2009
cb450sc's Avatar
cb450sc is an unknown quantity at this point
Does anyone know where the charcoal evap canister is located on a 1998 Civic LX? It is not in the owners manul. The Haynes manual for 1996-2000 Civics states that it is on the drivers side against the fire wall. Can't find it there either. I have a 1457 code showing up so I want to check the hose connections first before I take it in. Just can't find the canister! Thanks!!
Old Mar 1, 2009
cb450sc's Avatar
Re: Evap Canister Location?
Found it!! Under the fuel filter.
Old Mar 2, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Glad you found it. Helms (factory) is the only manual to trust IMO .
Old Aug 20, 2010
Guss's Avatar
Guss is an unknown quantity at this point
Hi dears,
I am quite new to this forum, however, quite familiar to my civic 98 (4 door). my check engine is on and technition (after asking CA$95 for deactivating the 1457 code and locating the problem) told that if it came again, it is due to canister check valve. Now it came again and I deactivated it three times by disconnecting the battry. I asked from Honda dealer in Quebec city, they asked around CA$257 just for the canister vent shut valve. So I have decided to change it.
The question is that:
where is the location of canister vent shut valve?
is non-origin canister vent shut valve appropriate?
Thanks
h4ldol
Apr 24, 2017 08:16 PM
senicalj4579
Oct 2, 2015 10:03 AM
deanaZoom
35
Sep 19, 2015 12:22 PM
Bricoleur
Sep 9, 2015 06:48 PM
