idle problem
Old Feb 28, 2009
r8dR supeRstaR's Avatar
r8dR supeRstaR is an unknown quantity at this point
Unhappy idle problem
well, first off im new to this site..and the problem im having with my 04 honda civic si hatch is that my idle bounces from 900 to a little above 2k rpm and after about 5 to 10 minutes with the car running, it'll start bouncing like it's red lining at 2k rpm..im thinking it's my idle air control valve..but im new to the newer year hondas..well, can anyone help me out..and if it is my iacvalve then where is it located, and what are the procedures that i have to do to take it out and clean it??? lmk thanks
Old Feb 28, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: idle problem
could be that. could be a vacuum leak as well.
Old Feb 28, 2009
Re: idle problem
you can try that, the iac is usually bolted to the throttle body and has coolant lines feeding into it. sounds more like a bad tps which means youll need a whole new throttle body.
Old Mar 2, 2009
blkcoupe1201's Avatar
blkcoupe1201 is an unknown quantity at this point
Re: idle problem
Im having the same problem with my 00 civic ex. It will bounce at 2k like its hitting revlimiter. I changed the idle control value and it stoped for a week then started back. I took off my TB and cleaned it still nothing. Im lost I have no idea what it could be.
Old Mar 2, 2009
Yaj00003's Avatar
Yaj00003 is an unknown quantity at this point
Re: idle problem
It could be a bad MAP sensor or a bad 02 sensor one of those or go to a autozone and look for a trouble code....
Old Mar 4, 2009
04 Honda Civic's Avatar
Re: idle problem
a bad o2 sensor can cause that?
Old Mar 4, 2009
shadymechanic's Avatar
shadymechanic is an unknown quantity at this point
Re: idle problem
If it's an 2004 Civic, you don't want to be replacing things that do not need replacing- costs big $$ on newer hondas. If you are not sure, and you are tripping a check engine light then go to your auto parts place - like an Autozone- and have them check it out on the scanning tool, first! A bad O2 sensor is often the culprit-the one above the manifold. Look for simple things first, leak in hose, dirty throttle body - especially if its a desert car or winter car. Check aircleaner connection as well.
Old Mar 5, 2009
Re: idle problem
I was wondering if it also could be a bad PVC vaule?? If so where is that located at on a 00 civic ex (d16y8)
Old Mar 5, 2009
Re: idle problem
hmm not exactly sure, some older engine had em right on top of the valve cover near the oil cap. newer ones have it down below on the right side of the engine and you gotta reach for it. kinda hard to see tho. theres a tube connected between it and the intake mani.
Old Mar 5, 2009
Re: idle problem
Probably above the oil drain plug somewhere. See if you can't see a blue or red colored piece with a hose going to it. You can usually see it with a bright light under the car.
Old Aug 18, 2014
allnet0300's Avatar
allnet0300 is an unknown quantity at this point
Re: idle problem
I swapped my whole throttle body and now the ifle problems is finally fixed , cleared the codes and then the check engine light came back on , so i was wondering my honda could have a bad computer , so if i change the computer ecu and see if that would solve and take away my check engine light . Watchu think?
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
