MY05 Civic Coupe Flasher Replacement
Old Jan 22, 2009
chazzguitar's Avatar
chazzguitar is an unknown quantity at this point
Hi All
First post here but I'm an active member on S2KI and hope you guys won't mind helping a Honda brother out. I'm at work and trying to help a coworker replace the flasher in her '05... we've got the part but don't really have any tools here. Shouldn't need them for this quick replacement. I just can't seem to get the old one out-- it is like -8349028 degrees here in Wisconsin and the fingers don't work too well when they're frozen solid.
Is there a trick to it (clip on the back or something) or is it just a finesse thing?
Thanks for your help
chazzguitar
Old Jan 22, 2009
CraigW's Avatar
Re: MY05 Civic Coupe Flasher Replacement
It looks like a clip is coming up the side and may hold the top edge/corner, the clip should just move side-ways and release hold. The connectors may hold it tight as well
Old Jan 22, 2009
on a 05 civic? mine just pulled out
Old Jan 22, 2009
Thanks for the prompt replies. I did see that clip on the side (in between the flasher and the small fuse tray on the fuse board, yes?) but remember there being a little bump on another side of the housing and didn't know if that needed attention.
And no, it certainly hasn't pulled right out! Maybe I'm just a sissy...
Thanks again
chazzguitar
Old Jan 22, 2009
CraigW's Avatar
Did you know the box will drop down if you take out the bolt at the bottom ??
IIRC I tried to remove mine once and it was tight (left it alone)
Old Jan 22, 2009
Yep, got the box dropped down but not too far as the wiring to some of the harnesses at the top of the box is extraordinarily tight. Precision manufacturing for sure.
Poopies
Apr 20, 2017 11:36 PM
miatabro
Jul 17, 2015 12:12 PM
shaejb15
Apr 26, 2015 07:44 PM
15EXCoupe
Apr 19, 2015 09:26 PM
CapYoda
Nov 11, 2001 05:17 PM
