type-s brakes and motor in 01 civic
ok i just got all 4 spindes with complet brakes on them, lower control arms, rims, suspension, sway-bars, and the axles and there all form a 02 type-s im getting the motor to, all this is coming from the same car 02 rsx-s ok no my qestion if i do the type-s motor swap can i do the type-s brake swap to, will the axles be to long or short? or do you have to use base rsx axle cuz ill be pissed if i have to use base rsx alxes cuz i bought the hole brake and suspension setup of a rsx-s damn im pulling my hair out over this
thanks
thanks
Re: type-s brakes and motor in 01 civic
well it is and isnt cuz now im not sure that i can do both brake coversion and the swap, cuz of axles and im just confused on the hole axle thing
Werd. Glad to hear another Bakersfieldian is going with rear disks. I think I finally have everything I need to put my 4-lug rear disk on. Might be this weekend since its a 3 day weekend. When are you doing yours?
Yep, EP3 and type S axles are the same, the spline is just different. You cannot use the type S axles with the EM2 hubs due to the spline, so you have to use the EP3. Since you have all of the suspension components then you actually need the type S axles and cannot use the EP3. So you are good to go, good luck to you!
tattedlariat
Apr 12, 2015 07:55 PM
