type-s brakes and motor in 01 civic
Old Jan 9, 2009
tribbcivic's Avatar
tribbcivic is an unknown quantity at this point
ok i just got all 4 spindes with complet brakes on them, lower control arms, rims, suspension, sway-bars, and the axles and there all form a 02 type-s im getting the motor to, all this is coming from the same car 02 rsx-s ok no my qestion if i do the type-s motor swap can i do the type-s brake swap to, will the axles be to long or short? or do you have to use base rsx axle cuz ill be pissed if i have to use base rsx alxes cuz i bought the hole brake and suspension setup of a rsx-s damn im pulling my hair out over this
thanks
Old Jan 9, 2009
manahoonie's Avatar
Re: type-s brakes and motor in 01 civic
talk to mr. fobster....
he has 5 lug swap w/ a k20
Old Jan 10, 2009
tribbcivic's Avatar
ok how do i get ahold of this mr. fobster?
Old Jan 10, 2009
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
Wow 2 threads of the same thing
Old Jan 10, 2009
tribbcivic's Avatar
well it is and isnt cuz now im not sure that i can do both brake coversion and the swap, cuz of axles and im just confused on the hole axle thing
Old Jan 11, 2009
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
if you're using all that stuff from the RSX-S, then you'll just use the RSX-S axles. works out totally fine.
Old Jan 11, 2009
tribbcivic's Avatar
ok man thats all i wanted to know thanks
Old Jan 11, 2009
lordhelmet's Avatar
Werd. Glad to hear another Bakersfieldian is going with rear disks. I think I finally have everything I need to put my 4-lug rear disk on. Might be this weekend since its a 3 day weekend. When are you doing yours?
Old Jan 11, 2009
01civ's Avatar
01civ is an unknown quantity at this point
i just did this ...heres a pic
http://i324.photobucket.com/albums/k...a/DSC00950.jpg
Old Jan 12, 2009
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
Yep, EP3 and type S axles are the same, the spline is just different. You cannot use the type S axles with the EM2 hubs due to the spline, so you have to use the EP3. Since you have all of the suspension components then you actually need the type S axles and cannot use the EP3. So you are good to go, good luck to you!
Old Jan 19, 2009
tribbcivic's Avatar
ya im getting the motor in a month or two depending on my tax return so thats when ill do the swap
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
vtechcivic
Apr 21, 2015 07:11 PM
tattedlariat
Apr 12, 2015 07:55 PM
Vtecpwr
Nov 11, 2001 10:17 PM
