Suspension Noise
Old Jan 9, 2009
lambada's Avatar
lambada is an unknown quantity at this point
Suspension Noise
My saloon '96 EK4 makes a thumping noise when I drive over unpaved roads. This noise isn't heard when I drive into a big bump but increases when the roads are wet. My mechanic is blaming the tie rod ends &/or rear trailing arm bushes. I am not convinced these are the culprits. What do you guys think?
Old Jan 12, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Suspension Noise
Where is the noise coming from? If from the front, be sure to check the upper control arm mounting bolts (found on the front and backside of the strut towers).
But, the rain 'shouldn't' affect this. Let us know a bit more information about the sound if possible.
Old Jan 22, 2009
Schuy's Avatar
Schuy is an unknown quantity at this point
http://www.popularmechanics.com/auto...o/4213443.html
Try the tool on that page, and see if it fits number eight, if it fits the description then you mechanic might be right.
Old Jan 23, 2009
goshinki's Avatar
goshinki is an unknown quantity at this point
Same thing happened to my car after my new shocks and coils was installed. mines made a clunking noise at the front passenger side for about 2 weeks and just went away right afterwords (when i was about to get it checked out). It could be your shocks or coils making the noise or it could be that something is loose underneath, like control arm brushing, sway bar brushing and end links etc. Get another mechanic opinion and take it from there.
Old Jan 23, 2009
if your springs dont have coil protectors (plastic cover on some of the springs), that might do it, or a bad strut mount bearing, or the shocks not being indexed properly.
Old Jan 24, 2009
lambada's Avatar
I have since changed the tie rods and rear trailing arm bushes. The noise from the front is gone and I've noticed a drastic improvement in overall ride quality. Problem is, there's still a noise coming from the back. It's a clicking noise when dry and thumping noise when wet! Going over a speed bump doesn't trigger the noise but going into a pot hole does.
My mechanic says the shocks and springs are fine.
Old Jan 24, 2009
ScottDR's Avatar
I'd check the rear upper control arm bushings. I'm not sure about the sound change though. I had one bushing (out of 4) dry rot but the car lived in the desert it's whole life.
You can change out an upper rear control arm yourself easily if you can change a tire. I bought one used for $10.
Hmm, the sound change. The more I think about this, the more I have other thoughts. I replaced one rear strut (stripped the allen head due to rust when I changed to Eibach Pro-Kit springs) with a cheap-o from Autozone. Ever since then that strut clunks and it seems to be more noisier in the rain. Interesting, do you have OEM struts?
Old Jan 24, 2009
could be rear sway bushing too
Old Jan 24, 2009
ScottDR's Avatar
It could be, if he installed one. The car didn't come with a rear sway bar from the factory (at least here in the states).
Old Jan 29, 2009
lambada's Avatar
Gearbox, you were right. My mechanic said I need to change the rear sway bar bushings and links. I've ordered the parts and they should be here in about a month. Sway bar was factory fitted.
Old Jan 29, 2009
ScottDR's Avatar
lambada: glad you figured it out!
Old Feb 12, 2009
kwandrew2's Avatar
kwandrew2 is an unknown quantity at this point
It might be your swaybar link. It connects your swaybar to your control arm. I replaced the suspension and all of the front bushings trying to fix a knock and finally when I came to the control arm bushing I took off the sway bar and seen that these links had gone bad. It is nearly impossible to tell that they are bad unless you unbolt the swaybar from it because of the way the bar hangs. Check it out...easy fix.
EdGasket
40
Nov 27, 2015 11:11 AM
Strycker
Aug 2, 2015 08:40 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
17
Jul 23, 2015 11:48 PM
mokkush
Jul 14, 2015 04:05 PM
