Steering wheel is wonky
Old Dec 19, 2008
CDN-Retard's Avatar
CDN-Retard is an unknown quantity at this point
CHeesy pic:
So I was driving and sorta drifted into a curb. the right front wheel kinda ricocheted at 40km/h. I think that's why the wheel is wonky. Now, i have to turn the wheel to the red line's angle (see above) to drive straight. It's very slight.
Is this an alignment issue? Is that how i should fix this?
if not, how else would i fix this? what possible parts are damaged?
Thanks for your replies in advance!
Old Dec 20, 2008
iwillbetrue's Avatar
iwillbetrue will become famous soon enough
Re: Steering wheel is wonky
I believe it to be an alignment issue because I had the same problem on a friends xterra who after had an alignment and everything was better.
Old Dec 21, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
Check your control arm. I did that last year on my sentra and it got destroyed.
Old Dec 29, 2008
natey57's Avatar
natey57 is an unknown quantity at this point
ur front toe is out.... get it aligned
Old Dec 29, 2008
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
do a visual inspection on the tie rod before you spend money on an alignment. if you bent the tie rod an alignment won't fix it and you'll have to replace it before your steering will be right again.
Old Dec 30, 2008
CDN-Retard's Avatar
Thanks for feedback everyone!!
I'll check the tie rod as per this DIY: https://www.civicforums.com/forums/s...archid=1581730
Hopefully it's just the alignment!!
Old Dec 30, 2008
natey57's Avatar
if the steering wheel is only slightly off, the toe adjustment will take care of it! the adjustment on the tie rod can fix a huge toe problem. the shop that does the alignment should do some pre-alignment checks anyway, to check for loose suspension components etc....
Old Jan 13, 2009
CDN-Retard's Avatar
was the Toe adjustment. thanks dude!!
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
alaga
25
Aug 13, 2015 04:42 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
qlitten
Jul 21, 2015 03:12 PM
