wiper not returning/no intermitent
Old Jan 8, 2009
largefries's Avatar
largefries is an unknown quantity at this point
hey! newb here. anyone have a problem with their wipers? My intermitent stopped working and they don't return were they are supposed to. I did a seach but couldn't find anything. It might be the switch, but thought I'de check before i go buy one. Also having trouble reoving the old one. I took out 2 screws but couldn't find anymore. the switch wouldn't budge. Anyone have a good 2005 manual? mine isn't very good. also looking for owners manual, is that online? (i lost mine ).
Old Jan 8, 2009
CraigW's Avatar
Re: wiper not returning/no intermitent
Do they stop in the same place each time ??
Does the mist function work ??
Old Jan 8, 2009
i think the switch gets stuck or something internally. i struggle with this on the 92 accord. most of the time the wiper just stops in the middle and i have to turn it past the intermittant so they go back down.
Old Jan 9, 2009
largefries's Avatar
Yeah, the mist works, int doesn't (I have 2 slow possitions now), and they don't return to the same possition, only if I time it right with the single wipe. If I shut off from the slow possition, it goes for a bit and shuts off randomly.
Any ideas? I hope its not the multi function unit behind the fuse box cause thats $488 from honda. yikes.
Old Jan 9, 2009
CraigW's Avatar
Here is the info from the manual, Let us know what you find out.
File Type: pdf
Old Jan 9, 2009
largefries's Avatar
thanks for the diagram, its the same one I've got though
I think I'll try replacing the switch (something tells me that not it) and then look for the control unit at a wrecker. I'll post what I find out.
Old Jan 10, 2009
natey57's Avatar
natey57 is an unknown quantity at this point
usually this turns out to be a bad wiper motor. The park switch inside doesn't tell the motor to shut off when they are in the "park" position, so they continue to run for a while, and stop wherever they want.
Old Jan 13, 2009
largefries's Avatar
thanks for the info! Maybe I'll try a wiper motor from the wrecker first. Seems to me that something is controling the motor and telling it when to "park".
h4ldol
Apr 24, 2017 08:16 PM
RSJ
Aug 13, 2016 01:06 PM
GotSiR
Jun 23, 2016 04:06 PM
Dsmak
Sep 10, 2015 08:30 PM
jpandjf
Aug 3, 2015 05:02 PM
