squeaky driver side window
Old Oct 28, 2008
my driver side power window squeaks like a **** when rolled up or down. sometimes i have problems with it rolling up almost closed and then slowing to a crawl. ive had some people tell me its a bad window regulator. if i open the panel, im not really sure what to look for. i also thought about lubing the tracks with silicone spray (the ones outside of the door panel where the window is in rolled up position).
Old Dec 31, 2009
01HonderCivic's Avatar
Don't be a n00b, search ftw
Re: squeaky driver side window
Hate to bring this back from the dead but mine has started doing this...Not all the time, only when it's dry outside and i've been driving with the window down in cold weather, around 30-40 degrees. ****'s getting on my nerves. Did you ever find out what it was?
Old Dec 31, 2009
yeah, i sprayed the tracks where the window slides with silicone spray lube. completely got rid of the squeaks. its best to do the lower tracks too by removing the door panel, but even the top ones will help (and some lube might trickle down to the bottom anyway). just roll the windows down and carefully spray inside each track. let it dry for an hour at least before using the window.
Old Dec 31, 2009
Sweet. I was afraid silicone spray would somehow screw with the window, like making it permanently cloudy or filmy...But thanks for the tip g-box.
Old Dec 31, 2009
unTuned's Avatar
i got another question, i was saying a few days ago i have this problem too. where exactly do you mean by the tracks? i have no interest (especially at this time of year) to remove my door panel and screwing around. i want to do only what i need to.
do you mean those two rubbery flaps that go across the door horizontal where the window disappears down into when you have it all the way down?
or is it the part on the side that sits vertical thats towards the rear of the door?
ive tried to listen to exactly where the sound comes from but i cant tell. also, does the silicone spray lube do any damage to tint?
Old Dec 31, 2009
CraigW's Avatar
There are front and rear tracks lined with a slick rubber lining. They are down inside the door and they hold/guide the window when it is in the lowered position. There are also tracks in the upper portion of the door as well.
Make sure you clean them all completely, and make sure the rubber inserts in the tracks are in place and not mis-formed.
Old Dec 31, 2009
guys you are spraying the silicone when the window is rolled down in the door, so there is no chance of getting any on the glass. you spray inside those two long, vertical channels where the glass moves thru.
Old Dec 31, 2009
Hondaguy89's Avatar
Hondaguy89 is an unknown quantity at this point
Hey gearbox, you said in your first post that the windows slows down as it reaches the top when closing. Did using the silicone lube spees it up any? Both of my windows are a little slow going up, especially the passenger side.. I think it may be the window motor.
Im also still a little confused on where you are spraying exactly. So you roll the window down. You dont take the panel off? So looking down where the window retracted spray inside there?
Old Dec 31, 2009
yeah after the silicone, it rolls up like normal. before it would almost not make it to the top. roll down the window, then spray the two rails that hold the window on each side. you are spraying vertical surfaces that are part of the door frame.
when you are looking at your car from the side, this is how it looks. spray each | from top to bottom. but usually when you spray at the top, gravity will carry the lube all the way down.
|window|
Old Jan 13, 2010
now that i was able to spray the BOTTOM channels that extend inside the door, the front windows roll up just like when the car was new! the rears didnt make any difference, in fact they were rolling smoothly, but thats prolly since there is only a couple inches of window track in the door. most of it is outside. but for the front windows, half the channel is in the door, so only doing the top part doesnt help completely. also both sides now roll down at the same time! instead of driver lagging behind
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
sonsonzai
Nov 4, 2001 12:52 PM
