Spark Plug Tick
Old Aug 30, 2008
TeraCivic's Avatar
TeraCivic is an unknown quantity at this point
Spark Plug Tick
I just put in a new amp in my 03 civic ex and i have all the wires separated the power on one side and preamps on the other and i have a tick from the spark plugs and as far as i know they are the same ones the factory put in how would i fix this problem could it be the spark plugs doing it or something else
Old Aug 30, 2008
Re: Spark Plug Tick
what does it sound like, ticking from speakers? you gotta make sure the factory grounds are tight and connected to bare metal, then run a new ground and power wire from stereo to battery. do not use stock factory harness for power and ground! also make sure your amp is properly grounded to bare metal.
Old Aug 31, 2008
TeraCivic's Avatar
Re: Spark Plug Tick
my amps are grounded to bare metal the radio is using the factory harness i'll try connecting it to the same as the amps thanks
Old Aug 31, 2008
TeraCivic's Avatar
Re: Spark Plug Tick
it didnt work
Old Sep 1, 2008
Re: Spark Plug Tick
are you using resistor style spark plugs?
Old Sep 1, 2008
TeraCivic's Avatar
Re: Spark Plug Tick
they might be they are the factory plugs so if i get different plugs will that help
Old Sep 3, 2008
Re: Spark Plug Tick
factory plugs are resistor, actually most you can buy are these days to cut down EMF interference. idk what else it could be. you sure the deck is okay?
Old Sep 3, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Spark Plug Tick
it didnt work
How do you have 4 posts in one thread without a single piece of punctuation?
Old Sep 3, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: Spark Plug Tick
valve adjustment?
Old Sep 7, 2008
TeraCivic's Avatar
Re: Spark Plug Tick
Originally Posted by 02BLKCIVIC
valve adjustment?
wat valve
Old Sep 8, 2008
02BLKCIVIC's Avatar
Re: Spark Plug Tick
what valve
the valves in your engine.
there are 12 of them.
and they tick when out of spec.
Old Sep 8, 2008
Tragedy's Avatar
skate or die
Re: Spark Plug Tick
^yeah they do when they are off.
IMO the d17 is naturally a little loud on the valve / spark side.
Old Sep 8, 2008
lordhelmet's Avatar
Re: Spark Plug Tick
What?
Old Sep 8, 2008
Tragedy's Avatar
skate or die
Re: Spark Plug Tick
I guess he forgot about the VTEC valve.
Old Sep 8, 2008
02BLKCIVIC's Avatar
Re: Spark Plug Tick
lol k
Old Sep 8, 2008
Tragedy's Avatar
skate or die
Re: Spark Plug Tick
Vteccccccccccccc Wooooo!!!!!
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
