Squeeking noise in rear strut
My car just now started making this weird squeaking noise in the rear left strut.. Not sure what is causing it.. Any ideas?
Re: Squeeking noise in rear strut
try spraying penetrating oil on ur camber kit, hte inner bushing, see if it dissipates, if it does, its typical, bushings squeak on camber kits regularly, drives me nuts
well that didnt work.. i sprayed zep 45 on the camber bushing and around the sway bar endlinks.. This is the first time its done it since ive had the cambers and ive had the same ones for alittle over 2 years
could it just be your shocks being worn?
my coilovers makes a little noise whenever I go slowly over speed bumps.
Tein says this is normal.
yes creeking - i know for a fact its my coilovers/shock because i just recently put my OEM ones back and they made a bunch of noise and my newly overhauled coilover shocks are a lot more quiet
well i dont think my noise is in the lower control arms because i get the same noise in the front whenever i go over speed bumps. I forgot to mentionthat sometimes when I spray a little white grease onto my coilovers it stops making that noise. It could just be the springs rubbing against the shocks somehow - but this could not be your problem...
edgenet
May 2, 2015 08:00 PM
