lets see what you think what is wrong with my cooling system!!
Old Jul 15, 2008
valenzuela's Avatar
valenzuela should not be trustedvalenzuela should not be trustedvalenzuela should not be trusted
when driving my cooling system gets over pressurized. the Rad cap is a new Honda OEM . i used a exhaust gas analyzer to see if there is Hydra carbons coming out of the coolant to see if there is a blown head gasket nothing came up there. the system is not leaking its holding all the pressure. i have heat inside the cabin. the radiator keeps pushing coolant to the over flow tank and the cooling system is not overfilled. my temp. gauge stays at normal temp. i check even with my scan tool and the idling temp. is 209F.soo its not over heating. if you have any suggestions let me know.
Old Jul 15, 2008
rednwhite04's Avatar
rednwhite04 will become famous soon enough
Re: lets see what you think what is wrong with my cooling system!!
why the new oem cap? was the old one bad or did you just swap it out hoping that would fix it? Did you just fill the rad.? Does it push coolant to the overfill until empty or does it stop at a certain level?
Old Jul 16, 2008
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
did you give Honda your VIN# and see if its a recall issue?
Old Jul 16, 2008
valenzuela's Avatar
yea i replaced the cap to see if it would fix it because our cap pressure tester was broken. and i checked there is no recall. i work for a honda dealership in indianapolis.
Old Jul 17, 2008
FGCOUPE's Avatar
not to be a complete *******.....lol
but if you work for Honda and you guys cant figure this out?
Old Jul 17, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
thats some funny ****
my idle temp is 190 and stays there once warmed up no matter how hard i am on it.
i say u got air in it. try bleading it that could also explain why it's a tad hotter than "normal"
Old Jul 17, 2008
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
that was my thought as well.
Old Jul 18, 2008
valenzuela's Avatar
well im not a tech at this dealership im still in school. nobody said i know everything on fixing a honda. im replacing the thermostat and flushing the system tomorrow. think i have a lazy thermostat. i have 144,XXX miles.
Old Jul 19, 2008
greeen01civic4d's Avatar
either that or a blown headgasket
Old Jul 19, 2008
FGCOUPE's Avatar
k, just for the record...
I never implied you directly
7thgensurvivor
38
Aug 29, 2015 11:50 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
hokiedad4
May 3, 2015 10:06 PM
bsmiley
Apr 27, 2015 01:27 PM
supercivic01
South
Nov 30, 2001 11:27 AM
