aftermarket alarm goes off at night
Old Jun 7, 2008
kcari's Avatar
It goes off for a quick 1 second noise/beep/chirp thats loud enough for me to hear. It only happens at night and it happens about 2-3 times each and every night. The alarm works fine though, for example goes off for the full amount of time when I kick the wheels.
What is this
Old Jun 7, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: aftermarket alarm goes off at night
What brand alarm?
Old Jun 7, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
sounds like a too-sensitive shock/tilt sensor. take it back to wherever you had it installed and have them adjust it. you don't want it so sensitive that wind or a bird landing on it will set it off. esp if it's as annoying as yours seems to be. but test it before you leave so that it's still sensitive enough to detect no-**** tampering with your ride.
Old Jun 7, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
i second that.
also, check your alarm grounds and if you have a backup siren battery thing, make sure it's not dead. i had an issue sort of like yours and it ended up being a ground that came loose somehow.
Old Jun 7, 2008
kcari's Avatar
I don't think its the alarm being too sensitive, since I distinctively asked for something not too sensitive. Often times I've kicked the wheels hard and that still didnt activate the alarm. Not until I really kick it with a boot or It usually takes a door or trunk getting slammed, does it go off. I also don't think wind is a factor because when parked in my garage it still went off.
so i guess, my issue could be a back up battery siren and a loose ground, i will bring that up when I bring it back to the shop, thanks
Old Jun 7, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
loose ground
Old Jun 7, 2008
kcari's Avatar
any idea on where the ground is placed?
Maybe I can just do it myself?
Old Jun 7, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
I second those opinions. It could be a bad battery or ground. Sounds like something like that.
Old Jun 7, 2008
DsevenEm2's Avatar
This is Myspace
wouldnt be the battery, id say a ground. when the connection (metal grounding points) are hot under the sun during the day, they'll stick together, completing the circuit. The alarm will only go off when the system is grounded, usually done by a switch or some kind of sensor. At night, the contact surface might be cold and not "stick" as well, so it grounds itself out. Its probably a loose ground wire, check to see where its routed under the dash or under the hood.
Old Jun 7, 2008
kcari's Avatar
does the installation of fog lights affect it by any chance?
Old Jun 7, 2008
no. they prolly did a stupid ground for the siren and put it on the bracket on a painted surface. check that and attach to a real ground.
Old Jun 7, 2008
kcari's Avatar
okay, thanks for that, i will definitely bring it to the shop and ask them about it.
Old Jun 11, 2008
kcari's Avatar
So I went to the shop today, the guy said something was wrong with my fuse wires and so he did something and now when I lock/unlock the car the lights, including my fogs blink on and off.
(does that waste battery life, btw?)
but anyways, I mentioned the ground wire, but he insisted something about the fuse... and to keep a long story short,
it went off tonight again, but the quick noise was a lot quieter.
Is there any chance if I don't get this fixed, it will affect my other electrical components?
thanks
Old Jun 11, 2008
i would still check the grounds. depending on where you got it installed, i'm going to assume they just screwed a really shitty ground into the firewall or kickpanel area, and it's crimped on and the wire is hanging by a thread.
Old Jun 11, 2008
Alright, seriously this time. What is the brand and hopefully model of the alarm we're talking about?
And if the ground was seriously shot, I'd expect the alarm to have a lot more problems than just chirping once or twice every night. I think something else is going on.
Old Jun 11, 2008
it can change depending on the weather. if its more humid, vs dry, and also when it rains. i had the problem where something would get wet and my alarm wouldnt work at all. ended up being a bad ground.
Old Jun 11, 2008
kcari's Avatar
I'm sorry I don't know the brand. The guy told me everything was fine. I told him specifically to check the ground wires and battery.
The difference is that it only went off once and it was quieter.
UltraHDGames
Jun 8, 2016 05:16 PM
cferry7
Oct 18, 2015 06:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
frank_kleng
Sep 29, 2015 10:55 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
