DRL and high beam not working, with buzzing noise
Old May 13, 2008
inmyturret's Avatar
inmyturret is an unknown quantity at this point
I have a 2003 Honda Civic (Canada).
A few weeks ago, I noticed a strange buzzing noise when I turned on the car. I thought at first that it was the air conditioning system. It would stop after about a minute. I found that if I turned on the headlights the noise would also stop.
Now the DRL warning light comes on intermittently when I'm driving, and the passenger side DRL does not work at all. The high beam on that side does not work either. The headlights work fine.
Anything I can try? Changing the bulb did nothing. I would really like to avoid a trip to the dealer (and the $40 cab ride each way).
Old May 13, 2008
Re: DRL and high beam not working, with buzzing noise
check the drl module behind the plastic panel where the hood release is located. and check the drl relays.
Old May 13, 2008
DDragon7's Avatar
I had the same problem, I at first I would just turn on my headlights, until one day I forgot to turn it off and it drained my battery. So after that I just disabled my DRL.
ORskier
May 3, 2015 12:54 PM
BoSS
Nov 27, 2001 04:55 PM
PimpBot5000
Nov 26, 2001 07:15 PM
klam
Nov 19, 2001 05:46 AM
godka0s
Bolt-on Engine Performance
Nov 8, 2001 07:16 PM
