Ac problems...
Old Apr 26, 2008
ElectroScantch's Avatar
ElectroScantch is an unknown quantity at this point
Ac problems...
I have a 2001 Civic LX 5-speed MTX with 210,000 miles. Recently the AC was pumping out no cold air, so I refilled it wil refrigerant R-134a... Before I stat pumping it into the system, the little meter attached to the refrig. refil can shows that I have no refrig. left, but as soon as I press the refill tab on the refrigerant can the PSI instantly jumps into the danger red zone (about 100 PSI). Anyone know what might be causing this? I can't imagine living in 110 degree weather without AC. Thanks for any help
Old Apr 27, 2008
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Re: Ac problems...
you need to have the car running with the A/C on when charging... Also there is a good chance you have a leak somewhere so you should find that before refilling the system.
Old Apr 29, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Re: Ac problems...
hmm...well that could actually be several items.....does the compressor come on at all? If not then jump the low freon switch (near drivers coolin fan) if the compressor turns on you definitely know you are out of refrig.
The most common location for D17 freon leak is at the line that bends 90 degrees in front of the drivers cooling fan. I've seen about a dozen that need that line. I believe it's the return line from condensor.
Old Apr 29, 2008
dopes6070's Avatar
Re: Ac problems...
Is it the upper line with the low pressure port on it? I probably should take a closer look at mine because I have a small leak that ive had trouble finding with uv dye and a light.
Old Apr 30, 2008
FoSho's Avatar
Re: Ac problems...
It's #3 on the image but it looks closer to #21........to the right of the condensor
See that 90 degree bend at the top of the line? Right there. They rub the a/c fan from the factory. Done alot of those! Even done it on my car! I couldn't find that leak either dopes. Something about the way it bends I couldn't get the UV **** to come out of it. I found it w/ an audible freon leak detector...thank you Honda
The line is called the A/C Discharge Line - $24.99 MSRP
Old Apr 30, 2008
dopes6070's Avatar
Re: Ac problems...
hmmm... interesting Ill have to take a look at that when I get home.
Old Mar 9, 2009
fondahonda's Avatar
fondahonda is an unknown quantity at this point
Re: Ac problems...
fosho your awsome !!!!!
looked at all kinds of stuff, relays mostly untill I found this post.
went outside and you were dead ***** on huge rub spot on the 90 deg coming out of the condinser at the bottom.
I will try and post some picks tomorrow for this thread
I might even take it up to honda just to see what they say thanks for the heads up
I owe you one
Old Mar 11, 2009
fondahonda's Avatar
Re: Ac problems...
some photos of the damaged line.
this is on a 2001 civic EX 1.6L
took about an hour to change out using the tools in the pic.
instalation was in the reverse order not removal of anything other than the line was required for me
hope this helps
Fondahonda
bobsagator
Jul 7, 2018 08:06 AM
ZILLA
Jul 5, 2015 05:24 PM
mrohitredd
May 28, 2015 10:03 AM
Xerois1337
Oct 6, 2013 09:08 AM
Mmg19
May 26, 2013 09:56 PM
