Suspension Problem
Old Apr 11, 2008
Honda05's Avatar
Honda05 is just really niceHonda05 is just really niceHonda05 is just really niceHonda05 is just really nice
Suspension Problem
Ok for some reason on the rear passenger side whenever i hit a pretty good dip of some sort or i have more than one person in my car and i turn left just that one side rubs against the rear panal or whatever you wanna call it..Just on the rear right..No problems in the front or anything.The rear left doesnt even do it. I thought maybe the springs were messed up so i bought a new set and it still did it so i bought new struts and it still did it..Then i bought new control arms and it still does it..Anybody have any ideas on what could be the problem..
Old Apr 12, 2008
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
Re: Suspension Problem
u have too many fat friends. thats your problem!
hahah...j/k
are u bottoming out on that side or just rubbing? cause if its bottoming out sounds like u need or forgot to put in bump stops.
are the struts and springs stock? if they werent i would ask about ride height and dampening setting.
tire might b inflated too much or mounted wrong, could b possibilites but if it was mounted wrong u would feel alot more than rubbing.
another question is how long has it been doin it and wat changes have u done to that side like new tires/rims(not wat u have done by replacing).
Old Apr 12, 2008
Honda05's Avatar
It never used to do that until i hit a big dip driven to ornaldo..It doesnt rub all the time.Just when when i hit a dip it hits rear panal..I have Tein S-tech lowering Springs, Tokico Struts, SPC Control Arms, Megan Cambers
Old Apr 12, 2008
crazyasian's Avatar
you might possibly have that side a bit too low or low enough to have it rub. idk if tokicos have a dappening setting but if it does check that out.
it really just sounds like your shocks are compressing down too much
Old Apr 12, 2008
Honda05's Avatar
Its not that low at all..The rear is only lowered 1.3inch..My left side is lower than my right and that side doesnt even rub
Old Apr 21, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
maybe the body roll is makin the tire hit the panel. roll it with a bat and a hammer lol. (the fender lining lip)
Old Apr 21, 2008
Honda05's Avatar
I dont think thats the problem..Then the other side should be doing the same thing.. I think the strut is just bad..I can get a new one for under 100 bucks so..Im gonna try that and see if it works
Old Apr 29, 2008
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
bump! im having the same exact problem with the same spring/strut combo.. did u fix it yet?
Old Jun 19, 2008
Honda05's Avatar
Sorry it took me so long to respond back but yes i fixed it..I have to readjust the camber
Old Jun 19, 2008
how much neg camber u running now?
Old Jun 19, 2008
Honda05's Avatar
That i have no idea cause i had my work done over at honda.. I have a guy over who does side work for me..But um what he did was he made the cmaber go in as far as it would go and just readjusted it from there and i havent had any problems since then
Old Jul 16, 2008
keepItJDM's Avatar
keepItJDM is an unknown quantity at this point
i would try replacing the strut should be the fix
Old Jul 16, 2008
Honda05's Avatar
close thread. Problem has been fixed for awhile now
Old Aug 27, 2008
gordongreg's Avatar
gordongreg is an unknown quantity at this point
If any of these conditions happens, it is probably advisable to stop the engine ASAP and try to find the cause before the system decides to go into "hard fault" mode.
Louisiana Alcohol Addiction Treatment
edspyhill09
Jun 12, 2016 02:45 PM
reqy
Jun 1, 2015 07:05 AM
oneheadlight
Apr 29, 2015 11:30 PM
