Bilstein sport struts review
Old Mar 21, 2008
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
I figured since not too many people have talked about the Bilstein sport struts I will post how I feel about them.
Basically I was looking for a high performance damper that was well suited for use with stock springs. But I also wanted them to be capable of handling a very mild drop of about an inch with progressive rate springs if I decide to do that in the future. I had KYB AGX's on my other civic and they weren’t really as firm as you would think for high performance shocks so I was looking mainly at Koni yellows and the Bilsteins. I didn't care about adjustability because I had it with the AGX's and only adjusted them a couple times and it didn’t seem to make a huge difference anyway. The reason I decided to go for the Bilsteins over the Konis is because I feel better about the beefy mono-tube design and the huge piston diameter. Plus they are close to the same price and the Bilsteins are easier to install. Knowing that Bilsteins are OEM equipment on many performance cars from BMW and others also weighed in on my decision.
I ordered them and they only had the front ones in stock and the rears where on backorder. So I got the fronts about 2 months ago and had to wait about another month and a half to get the rears. One thing to note is that the Bilsteins come with 16mm crash bolt holes instead of 14mm like on the 01-02 so there is some extra play room for camber adjustment even without a camber kit if you have a 01 or 02. I don’t think it will cause any problems but I just thought I would let everyone know. On the first drive the difference was immediate. They are very firm compared to stock and the car no longer wallows and bounces over bumps in the street like it did with my 125k old stockers (note my stock shocks where still good not leaking, just a little weak). It’s so nice to go over a speed bump and not have the car bounce around.
I can honestly say that my car with stock springs and non performance oriented 195/60/15 tires handles much more confidently. It feels more responsive and the body roll was reduced as well. Buying these was WELL worth the wait and money I had to spend. I would do it all over again if I needed to.
Old Mar 21, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Bilstein sport struts review
Nice review. Not many people have these.
Pics of install or on the car? What springs are you using?
One thing, you run the risk of camber slipping with the 16mm bolt holes. You have to be sure you tighten the bolts really well. However, if you take a corner too hard, things will eventually slip.
Old Mar 21, 2008
ronaldo9's Avatar
Can they handle a drop though?
Old Mar 21, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
I have the B+G full coilovers.....suppose to be the bilstein strut/shock. I friggin love em! Awesome A++ handling.....I beat the every living **** out of em and they're still going.
Blew out my compliance bushings before anything else
Old Mar 21, 2008
dopes6070's Avatar
Im using stock springs just cause I dont like having to crawl over dips and speed bumps.
Im pretty sure the camber bolts wont slip because there is some play even with the stock struts for minimal adjustment. and if they do I have lifetime alignment so It will be ok. I was thinking if I find a crashed 03-05 ill take the knuckles but untill then im sure its fine.
Old Mar 21, 2008
dopes6070's Avatar
Ill take some pics when I get home today. They look sick lol
Old Mar 21, 2008
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
waiting for the pics...i just ordered the tokico blues (front & rear). I just need a camber kit now then i can get the drop.
Old Mar 21, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Good to hear about the Bilsteins. I was wondering about those. It's really helpful for me to hear they work with stock springs, because I have the GC Springs designed for the OEM shocks so I was thinking about getting the Blues, but we'll see now.
Old Mar 21, 2008
dopes6070's Avatar
I’ve drove cars with the blues and they are pretty good. Much better then stock but its still not firm. The Bilsteins have a much higher dampening capacity and seem to be better built. These defiantly wont work with any sleeved coilovers since the diameter of the shock body is much bigger then stock in both the front and rear.
Old Mar 21, 2008
pheaton's Avatar
You should chime into my thread about suspension. I've never done anything with suspension ever, so I'm a real n00b with it. I'm trying to learn before I go or it. And realize I have the wrong parts.
https://www.civicforums.com/forums/1...ml#post4298810
Old Mar 21, 2008
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
in for pics. how much did the set cost you?
Old Mar 21, 2008
DsevenEm2's Avatar
This is Myspace
x2 and how big of a drop can they support?
Old Mar 21, 2008
dopes6070's Avatar
I wouldnt want to drop the car very low with these maybe like 1.5" or so... Ill give Bilstein a call on monday and get a for sure answer. Pics comming right up
Old Mar 21, 2008
dopes6070's Avatar
Ok here ya go...
ID:	73911   Click image for larger version
Old Mar 23, 2008
dopes6070's Avatar
Pics up
Old Mar 25, 2008
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
Bob,
I'm glad you've decide to join me. Hope the ride in my car was a contributing factor to your decision. Thanks for helping me with clutch job last time. Would you be interested in helping me replace the front control arm bushing with poly ones? PM me it you're intersted.
For those who are interested, I did an initial review two years ago on the Bilstein here: https://www.civicforums.com/forums/4...very-long.html
I've since put over 40K miles on it and they are still working like new. Best shocks I've ever put on a car IMHO.
Old Apr 16, 2008
L23Tan's Avatar
L23Tan is an unknown quantity at this point
EX4Dr and dopes... awesome reviews!
Does anyone here have these Struts/Shocks installed on their 2001 or 2002 vehicle?
2001 & 2002 Civic's have 14mm Crash Bolt Holes.
After calling Bilstein, they confirmed that the Struts they produce for our cars are 16mm holes, intended for a 2003-2005 Civic's.
Is there a way around this small issue, if I were to get these Struts/Shocks installed on my 2002?
I'm thinking there might be some kind of Washer or something that can be used?
Has anyone here have any ideas or have encountered/solved this problem?
I've read many posts about people enlarging the hole on their suspension to accomodate the 16mm hole, but not once have I read it the other way around.
Any kind of input would be appreciated.
Old Apr 16, 2008
wheelspinLX's Avatar
wheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nice
^ How would a washer help if the holes in your suspension are 2 mm too small? LOL You have a 2002 that has 14mm holes and you need 16 mm holes so the only solution would be to drill them out... correct me if I'm wrong.
Old Apr 16, 2008
L23Tan's Avatar
Not sure if this is the washer, as I haven't confirmed yet... but if you look at Page 9 of this link http://www.tein.com/tech_info/inst/2a22u.pdf... bottom left... there are 4 washers, Part Number: SAP40-G1985.
I could see those washers working, because if the inner diameter of the washer hole is 14mm, and the remaining 2mm is to sit flush along the inside of the Strut Mounting Bracket hole of 16mm, it should work.
I'm also trying to find an actual picture of the washer right out of the Tein SS-P or SS box.
Old Apr 17, 2008
metalviper's Avatar
wrong. he would have to replace the lca. hes looking for washers that fit inside the clevis bracket to minimize the gap in the bracket between 14mm and 16mm. all i can say is call around your tein dealers
Old Apr 17, 2008
My bad, I stand corrected.
Old Apr 17, 2008
dopes6070's Avatar
14mm bolts with the Bilsteins does work as long as its tightened to spec. Thats the way I have it and I havent lost the alignment. You just have a little bit of wiggle room for different alignment settings. It wont cause any problems. My car is an 01 sedan
Old Apr 18, 2008
FoSho's Avatar
Anybody got a link to a decent price? Every bilstein front struts is like double the koni's!!!??
Old Apr 18, 2008
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
check the forsale section.. exturbo is thinking of selling his
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
