Measuring the front struts? v.50or55mm
Old Mar 12, 2008
JamesL's Avatar
JamesL is an unknown quantity at this point
Got a bit of an odd problem here.
I went with Ground Control/Koni setup back in 2002. My EM2 is an 02 as well. I have no recollection of the front strut size.
I have looked everywhere in my garage and can only find my original rears And of course, only the box for the rear Konis. I cannot find the invoice, despite having saved every receipt for every modification on my vehicle meticulously in a file cabinet.
Given that I have GC/Koni setup on the car now, how do I go about measuring the fronts? The GC sleeve covers all of the Koni...
I am coming to the realization that I might have to dissassemble the fronts to measure... Anyone have any ideas about measuring before I do so?
Old Mar 12, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Measuring the front struts? v.50or55mm
Kinda long winded for a simple fix All you need is a set of electronic calipers then go outside and measure it.
http://www.amazon.com/NESCO-NM-9560A.../dp/B000FKQDDS
Old Mar 12, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Should only have to jack the car up to measure. I think? Anyone?
Old Mar 12, 2008
JamesL's Avatar
Maybe I am missing something...
Where exactly am I measuring?
I jacked the car up today, and the coilover sleeve covers the Koni housing...
Old Mar 12, 2008
robbclark1's Avatar
You measure the diameter of the Koni. You should be able to wiggle it in between the spring.
Old Mar 12, 2008
JamesL's Avatar
I thought we were measuring the housing itself(ie: the yellow exterior of the canister) not the shaft?
Old Mar 13, 2008
robbclark1's Avatar
I never said anything about the shaft, but you should have some of the yellow piece showing don't you? What springs do you have on there? Can you take a pic so I can circle where to measure?
Old Mar 13, 2008
JamesL's Avatar
I'll jack it up again today at lunch and get back to you with a pic. I have the standard 6", 2.5" ID Eibach springs.
When I did it yesterday I didn't see any yellow poking out (albeit, it was rather dark in the parking garage).
Old Mar 13, 2008
JamesL's Avatar
Well... It turned out to be darkness coupled with dirt that obscured the view of the strut housing. Although, the amount sticking out that you have to work with is rather small. I had to pull the fender liner off to get a good measurement.
They ended up being 55mm.
Thanks for the help all.
Old Mar 13, 2008
robbclark1's Avatar
hans.pcguy
Jul 12, 2015 12:19 PM
Fudman
Jun 2, 2015 01:26 PM
beachglass
Jun 1, 2015 08:28 PM
beachglass
May 22, 2015 09:59 PM
GH04si
Apr 15, 2015 08:13 PM
