Maybe squeaky belts?
Old Feb 28, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Eh, I have what sounds like a squeaky belt of some kind. I think I'll get a video of it up or something, but does anyone know if there are any common problems with squeaky belts or squeaky parts, in the engine bay? It's just so annoying, I guess it's a pet peeve of mine. Reccommendations?
Old Feb 28, 2008
Re: Maybe squeaky belts?
usually the belt is too loose or too tight. the suspension can make squeaks in the winter when car is moving too.
Old Feb 28, 2008
speedfoos's Avatar
Don't talk to me about squeaks......I got one that I can't figure out either that's definitely not the belts. Like gear said, check the tension on the belts. Could also be a bearing in the alt or PS pump.
Old Feb 28, 2008
Eyger's Avatar
Hm, I really need to get a chilton guide or something. Because I don't even know how to check the tension in the belts.
Old Feb 28, 2008
get a haynes or something, doesnt have to be the big honda manual if you just need something for simple specs. but to answer your question, there are tools that measure deflection, or you can use your finger lol
Old Feb 29, 2008
carter's Avatar
carter is an unknown quantity at this point
i get this chingging noise when the wheels are moivnig seems to be coming from the tire area maybe the engine bay.. if the wheels stop moving noise goes away but if the wheels start moving noise comes back its like clinging of likee amillion nickles and dimes jus ringing off one anohter. I put it in N and rev da engine no sounds noothing only when wheels move Front OR Backwards.
ANY Ideaa?>??
Old Feb 29, 2008
wheel bearings? are your brakes okay? sometimes the wear indicators sound like that when the pads get low.
Old Feb 29, 2008
carter's Avatar
When i last check that site of the car ... (the only wheel i took off was that side) It had baout 35%-40% pad still left. I got some Brembo Blanks and Hawk pads to go on once the weather clearsup. Last time i checked was about a month ago so i guess pads are probably 30% or less.
Does that help?
Old Feb 29, 2008
carter's Avatar
I drove the car today just like 20min ago for a good 30min or so no noise.. It comes and goes... It could be the brakes but they make a sound like that they have such "indicators" ? How low should you go before you change the pads?
Old Feb 29, 2008
Eyger's Avatar
^Thank you carter.
Anywho. I'm getting my transmission repaired soon, if it doesn't go away after that, then I'll look into it more.
Old Feb 29, 2008
carter's Avatar
Sorry bro i thought you already had your problem solved.
Old Mar 1, 2008
Eyger's Avatar
^ha ha, it's all good I'm just messin with ya. I hope the squeaking problem goes away after I get the trans fixed. If not then I'll post back in here and see what I can dig up.
WaryDriver
Aug 22, 2015 06:50 PM
WaryDriver
Aug 16, 2015 11:22 AM
Ray Darvi
Aug 12, 2015 11:55 AM
WaryDriver
Aug 8, 2015 05:08 PM
1khilari
Jul 9, 2015 08:12 PM
