1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Installing cruise control on '90 CRX auto trans
Old Feb 16, 2008
MultiCRX's Avatar
MultiCRX is an unknown quantity at this point
Question Installing cruise control on '90 CRX auto trans
I was at junkyard yesterday and noticed a '91 Civic DX auto trans w/cruise. I thought it might not be too difficult to install on my '90 CRX auto trans. car. Has anyone done this? First items I noticed were:
1) the cruise control module on the drivers side motor mount w/throttle cables to the throttle body and also back to the pedal assembly;
2) steering wheel w/cc buttons;
Things I didn't immediately notice:
3) probably a "cruise" light in the instrument panel;
4) " some sort of module under the dash;
5) " some sort of speed pickup...tach wire off distributor?
6) maybe some sort of vacuum accumulator? &
7) brake pedal disconnect.
What else?
would some of this wiring already be present in the stock CRX harness?
Thanks
Old Feb 17, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
Re: Installing cruise control on '90 CRX auto trans
i dont remimber all the nitty gritty dietails but i do know tha tonly the 90-91 LX and EX sedans came with cruse. from these cars u can get the actuator (as u described) the sterring wheel for the buttons, the cluster for the light(all should be compatible i thing the 90-91 were wired diffrently but worth the oem look), and the cruse switch, and the CC brain mounted above the gas pedal. i'd get the plugs too in each componit and just tie into the points needed. the saftey switch should allready be in the shifter switch on the shifter.
OptimisticWay
27
Jul 6, 2015 12:56 PM
civic__duty
24
Jun 11, 2015 12:29 PM
MamaBear2015
May 27, 2015 12:04 PM
cukaracha
May 16, 2015 02:11 PM
davidpaustin
Apr 29, 2015 02:23 PM
