1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
ECM (6) code problem
Old Feb 2, 2008
Inliner 44's Avatar
Inliner 44 is an unknown quantity at this point
I have a 89 Civic 1.5 hatchback that keeps setting a (6) code on the ECM. I have replaced both temp sending units and the thermostat. The motor is not hot, I’ve checked it with a laser thermometer. It will set the code within a few seconds of starting the engine. If I let the engine come up to operating temp I can watch the thermostat cycle with the laser. After the motor is warmed up, I can kill the engine and reset the ECM and it will run all day without the check engine light or the 6 code coming on. Let it cool down, start it up and bingo the check engine light and 6 code come back. This is making me nuts.
Thanks for your help.
Old Feb 11, 2008
civicninitwo's Avatar
civicninitwo will become famous soon enoughcivicninitwo will become famous soon enough
Re: ECM (6) code problem
Just to be sure, if you have on available, substitute a known good ECU. I know it sounds like something you've already heard from a manual or something. It is one true way to use process of elimination to figure out your problem. They do go bad,sometimes.
peace,b
Old Feb 25, 2008
RonJ's Avatar
RonJ will become famous soon enough
In addition to a faulty ECU, you should also consider a problem with the TW sensor circuit:
Old Mar 30, 2008
shortys1519's Avatar
shortys1519 is an unknown quantity at this point
you can also get on google and there is a way to reset your ecu after you fix the error so the code wont keep coming up
tmort
May 11, 2015 07:13 PM
tylerginevan
Apr 27, 2015 12:29 PM
tkcne
Apr 18, 2015 02:33 AM
BREADFAN
Apr 15, 2015 08:58 AM
dooner24
Apr 14, 2015 07:51 PM
