ECM (6) code problem
I have a 89 Civic 1.5 hatchback that keeps setting a (6) code on the ECM. I have replaced both temp sending units and the thermostat. The motor is not hot, I’ve checked it with a laser thermometer. It will set the code within a few seconds of starting the engine. If I let the engine come up to operating temp I can watch the thermostat cycle with the laser. After the motor is warmed up, I can kill the engine and reset the ECM and it will run all day without the check engine light or the 6 code coming on. Let it cool down, start it up and bingo the check engine light and 6 code come back. This is making me nuts.
Thanks for your help.
Re: ECM (6) code problem
Just to be sure, if you have on available, substitute a known good ECU. I know it sounds like something you've already heard from a manual or something. It is one true way to use process of elimination to figure out your problem. They do go bad,sometimes.
peace,b
peace,b
tylerginevan
Apr 27, 2015 12:29 PM
tkcne
Apr 18, 2015 02:33 AM
BREADFAN
Apr 15, 2015 08:58 AM
dooner24
Apr 14, 2015 07:51 PM
