Fog Lights on 8th gen coupe
Old Dec 27, 2007
07exNavi's Avatar
07exNavi is an unknown quantity at this point
Ok I just bought some JDM fog lights from Ebay for $65 shipped, I think this is a pretty good deal considering that the factory honda ones are $300. I was wondering what I need to know to install these, I am a little worried about putting the switch in the dash and how to actually bolt the fog lights onto the car. I think I can figure out the wireing. Any suggestions would be helpfull.
The lights should be here within a week.
Thanks.
Old Dec 27, 2007
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
Re: Fog Lights on 8th gen coupe
there will be some cutting of plastic involved in the install as far as the lights go, the switch should just pop in place of the plastic place-holder
Old Dec 27, 2007
Rennen's Avatar
New Mod on the Block
good luck. hopefully u got a good kit. my ebay fog kit didnt fit for ****. i had to custom wire it.
Old Dec 27, 2007
07exNavi's Avatar
How do the plastic place holders pop out? and what panels do I need to remove to run the wires? I was gonna put it where the stability controll on the SI is, to the left of the steering wheel.
http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
that is what I got, it looks like it has good brackets to mount them with and some decently made wireing harnesses.
Old Dec 28, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Remove the bumper
Cut holes in bumper with SHARP utility knife, but mask around the foglight holes first
Install fogs/brackets into backside of bumper
Foglight harness - Plug it into the fogs, the other end has a 1-pin plug and a loop for ground. The loop is grounded to the chassis right up front on an existing bolt (youll see it when you have the bumper off), the tricky part is locating the 1-pin connector ON the honda, I suggest taking off a few pop rivets found on the passenger side spalsh guard (after tire removal).
Then youll see a brown 1-pin connector hidden up in behind the washer resevoir, Plug it into the fog light harness!
Once this is done install your bumper back onto the car.
For the next part (under your dash) PM me for details!
Old Jan 3, 2008
deviousin10tion's Avatar
deviousin10tion will become famous soon enoughdeviousin10tion will become famous soon enough
Here is a manual I found for an Si model shouldn't be too much different.
http://www.handa-accessories.com/civic/072rdsi.pdf
Old Jan 3, 2008
07exNavi's Avatar
Thanks devious I think that will be very helpfull. The lights still havent gotten here yet, so Ill let you all know how the install goes after I get them.
Old Jan 5, 2008
07exNavi's Avatar
They should arrive on the 9th.
Old Jan 12, 2008
07exNavi's Avatar
I am about half way through the install. the lights are in the bumper but the wires arnt all hooked up yet.
Old Jan 12, 2008
Emerican's Avatar
Emerican is an unknown quantity at this point
Hey i might be having the same problem, idk. I have a 07 civic ex coupe, and i got some JDM fog lights. I got through all the steps until the last couple using an OEM honda instructions manual. It says something about a white/red terminal and a blue one, but i don't have a blue one. is this because its JDM and is there anyway to still install it with this? or is this something wrong with the light wiring?
Old Jan 12, 2008
07exNavi's Avatar
I stopped after I got everything done except the work inside the car, so the switch and another wireing harness left to go tomarrow.
Old Jan 12, 2008
07exNavi's Avatar
Emerican, I am haveing the same problem. I have no clue what to do about it. I think I am going to try to hook up just the red/white wire and pray that it works. I am hoping that the blue wire is somthing a little bit unessesaarry. I let you know how that goes tomarrow. Did you have a prolem with the brown connecter in the right fender? Mine wouldnt go together and I hade to bend the metal clips inside the female end to get it to fit.
Old Jan 13, 2008
07exNavi's Avatar
To answer your question, when you get to the final wireing harness. You need to put the red/white wire into where it says in the instructions, then plug one of the blue connectors in above the fuse box. Then hook up the other connectors and the ground like in the instructions. Hope this helps, and dont forget to put in the fuse after you are done, that was frustrating for a minute lol.
Other than that I have them fully installed and they look and perform great.
Old Feb 10, 2008
07exNavi's Avatar
Pics.
Old Feb 10, 2008
nice!
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
