D2 End Links!
Old Dec 12, 2007
icetrap's Avatar
icetrap is an unknown quantity at this point
D2 End Links!
I have a rear 22mm JDM Integra DC5 Antiroll bar. I'm worried that the end links will break one day.
I found that that D2 Racing do have the after market endlinks. Anyone using them?
Pictures from my friend's car
Old Dec 12, 2007
Da1lyDr1ver's Avatar
Re: D2 End Links!
i dont really think you have to worry about the endlinks breaking with the RSX-R rear swaybar. i have the same bar with OEM endlinks and i do quite a few road races with it in the summertime. no problems to date.
i think a lot of people are afraid of the endlinks breaking because Progress had a problem with their rear swaybar that caused our OEM endlinks to snap eventually. i dont think the same goes for the rsx bar.
Old Dec 12, 2007
icetrap's Avatar
Re: D2 End Links!
Thanks dude. Cause I'm using the 22mm not the rex bar which is 19mm. By the way, next time you jack up your car, help me check your end links, or even better take some pictures. I will be tempted to try the end links from D2 if it helps.
Then again, I know some guys who used the JDM end links and the end links broke off.
BTW, what do you use for the bushing dude?
Old Jan 8, 2008
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Re: D2 End Links!
Those endlinks in that picture look the same as OEM ones? Unless its just a bit thicker?
Old Jan 8, 2008
Re: D2 End Links!
get the dezod endlinks they look much better
Old Jan 8, 2008
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
Re: D2 End Links!
you can always try grey's endlinks from this forum...here's the link... bought mine from him not to long ago but i'm just waiting on my jdm (22mm) sway bar, same as yours...hope it helps
Old Jan 8, 2008
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
Re: D2 End Links!
^^^you can do the greys endlinks or you can search there was a guy on here that made his own and then gave the part #'s for all the parts. i would go that route.
Old Jan 8, 2008
Re: D2 End Links!
those pics in the first post are just stock endlinks lol!
Old Jan 8, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Re: D2 End Links!
I'm running the Progress rear sway bar which is 22mm and I run stock end links. My 27mm bar that I sometimes run upfront has stock endlinks to. I have never broken a stock endlink before and I track and auto-x cross my car hard most of the time when I am Auto-xing I am usually on 2 to 3 wheels at all times on rare occasions 4 lol! the stock endlinks are more than strong enough to handle all of your needs.
In all honesty you don't need aftermarket endlinks save your money
Old Jan 9, 2008
skipbarber's Avatar
Re: D2 End Links!
im using stock links since 03 with my progress bar. no problems..
Old Jan 9, 2008
Nameless's Avatar
TURTLEonK
Re: D2 End Links!
Thats what I said! LOL!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
bsmiley
Aug 13, 2015 10:32 PM
jzhartman
22
Jul 23, 2015 10:42 PM
fordover
Jul 11, 2015 09:10 PM
