02 civic suspention lowered BANGING???
Old Oct 6, 2007
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
ok I hate this. I have an 02 civic and Im lowered on progress springs and tokico blues.
and let me tell you
I HATE IT. every bump i hit it SLAMS like its bashing into my bump stop. I have it cut more then halfway and it still hits hard.
Is this suppose to be like this?
It's so shitty when im going fast down a road and i hit a bump and loose control. these are only a few weeks only and have done it since I lowered ughh
Old Oct 6, 2007
MidnightCivic's Avatar
Re: 02 civic suspention lowered BANGING???
you should change your sig to "Soon to be slammed "
Old Oct 6, 2007
AmbulanceMonkee's Avatar
that's shitty. could there be anything wrong with the springs or dampers?? was everything new?? Struts leaking at all?? Did you DIY the install?? Are you sure it's right?? How low is it when it's just sitting there?? could be any number of things. search around the site, see if anyone with that setup has had problems. good luck getting this worked out.
Old Oct 6, 2007
popee's Avatar
popee will become famous soon enough
my friend has the same problem we have to replace his rear struts... sounds like its claping?? from the back..
Old Oct 6, 2007
So.Ill.EM2's Avatar
Ultra-Platinum Super Bonus Member
So.Ill.EM2 is just really niceSo.Ill.EM2 is just really niceSo.Ill.EM2 is just really niceSo.Ill.EM2 is just really nice
i'm on blues and eibach reds and i have no problems. did you DIY? if yes then you might have f'ed something up. if not, then take it back to the shop and have it checked. sounds like a strut problem if it's stiff. if you're bottoming out, the springs are too soft. i dunno man, but get it checked out, suspension problems can ruin a car faster than anything.
Old Oct 6, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
The drop on Progress springs is a little more than 2 inches right? I'm pretty sure they're too low for the Blues, but I'd call Tokico to be sure.
Old Oct 6, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
my first question is, did you trim the bumpstops when you replaced the springs and struts/shocks?
second, as monkee said, was everything new? how low is it at rest? crawl underneath and see if you have any clearance issues, look for damage, signs of rubbing, dents, etc...
if you can't find any visible damage, you may have to replace your shocks as they may be blown. are you hauling around a lot of stuff in your car? subs/amps, tools, fat chicks?? start simple and work your way toward more expensive man. GL to you
Old Oct 6, 2007
Originally Posted by tuningmycivic
...are you hauling around a lot of stuff in your car? subs/amps, tools, fat chicks??...
repped.
Old Oct 6, 2007
sometimes, ya just gotta ask
*edit: gotta spread some rep around bro
Old Oct 6, 2007
greeen01civic4d's Avatar
i agree, progress springs might be too much of a drop for these struts, id contact tokico about that one
Old Oct 6, 2007
^true. preferably before you destroy the struts.
Old Oct 7, 2007
Maple50175's Avatar
Yes everything was brand new.. and it's happened since I lowered it.
everything is right. its comming from the front. the bumpstop is cut 1/2 off. and I have a feeling its still hitting it...
blah damn civics, i miss my accord
Old Oct 19, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Have you solved your problem yet?
Look into your fender well and see how compressed the springs are when the car is on the ground. If the coils are almost touching each other or are touching each other, thats probbably the problem. You do not have enough suspension travel period.
You'll need different springs to get rid of that.
Old Oct 20, 2007
nyghtryder's Avatar
nyghtryder is an unknown quantity at this point
i know this is sounds stupid but you didnt reverse the springs right, front on the rear. that will give you similiar results since the rear spring rate is not designed to hold the weight of the engine. otherwise contact progress and talk to them about swaping out to higher spring rates. most companies will help if you pay for the shipping.
Old Oct 20, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
i dought that happened. the front a rear springs are different sizes the front springs wont even fit on the rear shocks!
Old Oct 22, 2007
Zzyzx's Avatar
Autocross Junky
Stupid question... But have you bothered to go back over the install and make sure all the bolts are tight? If the upper mount is loose it makes an awful racket.
"Banging" typically means something is loose.
Old Oct 22, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
i'd also highly recommend going back through and checking your install. any time i have replaced suspension components on my car, i usually drive for a week then go back through and TORQUE all the bolts and nuts. even having something TOO tight can make noise. also, i really do think progress springs drop the car too low for blues.
Old Oct 27, 2007
LoneWolf's Avatar
LoneWolf is an unknown quantity at this point
I think the blues have a limit of -1.7
Old Oct 28, 2007
CenZ's Avatar
PWIT
my blues do that too. i got gold lines on my blues and im on 205/40/17 so yeah. i dont know. everything is tight, the springs are on good. it doesnt happen all the time. but i think its more my rims than anything else.
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
EvilTwin
Nov 8, 2001 12:17 PM
2Hondaz
Nov 8, 2001 11:00 AM
Zillaaa
Nov 2, 2001 05:11 PM
