Tranny / Criuse Control Issue
Old Sep 18, 2007
deetek's Avatar
deetek is an unknown quantity at this point
I just wanted to post what happened to me, to see if anyone else has experienced this problem. If not, then if this happens to you, you will at least know what the problem is.
About 3 days ago my 2005 civic, with only 22,000 miles on it (still under warranty) started slipping while in first gear. It is an automatic. When I would be at a stop and pull off, it would rev and hesitate and then grab into gear. It scared the hell out of me. I thought it was for sure my transmission. Also, I was hearing a rattling noise in the console where the stick shifter is.
Well, I took it to the dealer, and it took them a whole day of checking the transmission to figure it out. Apparently the cruise control mechanism under the hood was malfunctioning and sending incorrect information to my tranny. So they disconnected the unit and apparently it stopped slipping. Whats really unusual is that I don't even use my cruise control, or even turn it on. But anyway, their gonna order me a new cruise control unit (its supposdly very expensive, but covered under the warranty luckily) and install it in a few days.
Anyway, has anyone had a simmilar problem to this. The mechanic at the dealer said he had never seen this before. I'm just worried that it may be a bigger problem than this. I don't understand how my cruise control can affect my tranny when its not even on.
Thanks!
Old Sep 18, 2007
Re: Tranny / Criuse Control Issue
its strange. but yeah in the computer age, anything will affect how the car runs. my tps sensor voltage was too high (related to throttle body) and it felt like the trans was busted, it wouldnt shift out of gear, or in gear, i barely limped it home. just because it was getting bad signals due to ecu telling it wrong info about air intake. trans is tied to cruise, because it also has to shift the gears when in cruise mode. doesnt matter if cruise is being used or not either. everything is always ON.
Old Sep 19, 2007
deetek's Avatar
Thanks for info.!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
MajTom
Jun 2, 2015 11:48 AM
cukaracha
May 16, 2015 02:11 PM
bsmiley
Apr 27, 2015 01:27 PM
JoeB16
61
Oct 16, 2003 07:58 PM
