need help replacing fuel tank 2004 civic
Old Aug 28, 2007
maniacz42's Avatar
maniacz42 is an unknown quantity at this point
hi, not new to the forum just finally registered today.
i need help how to change my fuel tank for a 2004 civic,
what tools are needed? and where are all the bolts are at? and are all the fuel tank on the 2001-2005 civic are all the same?
thanks in advance guys
Old Aug 28, 2007
_Viper_'s Avatar
Re: need help replacing fuel tank 2004 civic
Ok well why change a 2004 fuel tank.. also the risks and fuel dumping are cery high... its not really a do it yourself think but basically a jack , ratchets, screwdrivers should do the trick.. also do not have any light sources around......perhaps a flashlight also be in a well vented area .......
why change a 2004 tank???? its new
Old Aug 28, 2007
Jza's Avatar
Jza
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
Maybe he's doing an '05 gas tank swap, I hear it gives you +2HP, lol.
Old Aug 28, 2007
Old Aug 28, 2007
maniacz42's Avatar
im replacing my fuel tank because i ran over a sharp metal object on the freeway and made a crack on the bottom of the tank so thats the reason why im replacing it. thanks gear box
Old Aug 28, 2007
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
gearbox to the rescue lol
Old Aug 29, 2007
speedfoos's Avatar
Good stuff as always gearbox. If you don't have that special fuel pump collar tool thing, just use a hammer and a brass punch to loosen it up. You just tap on the collar ribs to get it turning in the right direction.
Old Aug 29, 2007
the main thing is relieve fuel pressure, so you dont cause any explosion
Old Aug 29, 2007
drunkenmagnum's Avatar
explosion ftl.
if he post again will determin if he was successful, if not then he died a horrible firey death
Old Aug 29, 2007
^^ lol.. that would suck if he didnt make it lol
Old Aug 30, 2007
_Viper_'s Avatar
If need be use those small propane torches to get the undercarriage screws loose lolllll
KABOOOOMMMMMM
Old Aug 30, 2007
yeah here is where common sense becomes important lol
Old Sep 1, 2007
maniacz42's Avatar
damn man why you guys gotta wish death on me, hahaha, thanks gear box for the help.
Old Sep 1, 2007
lordhelmet's Avatar
Set up a webcam so we can watch you loosen your bolts with a torch.... for educational purposes of course
McD
Apr 29, 2015 03:50 PM
McD
Apr 22, 2015 05:28 PM
chgofirefighter
Apr 18, 2015 08:08 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
thesushiboy
Apr 12, 2015 02:54 AM
