need help replacing fuel tank 2004 civic
Rep Power: 0 need help replacing fuel tank 2004 civic
hi, not new to the forum just finally registered today.
i need help how to change my fuel tank for a 2004 civic,
what tools are needed? and where are all the bolts are at? and are all the fuel tank on the 2001-2005 civic are all the same?
thanks in advance guys
Rep Power: 316 Re: need help replacing fuel tank 2004 civic
Ok well why change a 2004 fuel tank.. also the risks and fuel dumping are cery high... its not really a do it yourself think but basically a jack , ratchets, screwdrivers should do the trick.. also do not have any light sources around......perhaps a flashlight also be in a well vented area .......
why change a 2004 tank???? its new
Rep Power: 0 Re: need help replacing fuel tank 2004 civic
im replacing my fuel tank because i ran over a sharp metal object on the freeway and made a crack on the bottom of the tank so thats the reason why im replacing it. thanks gear box
Good stuff as always gearbox. If you don't have that special fuel pump collar tool thing, just use a hammer and a brass punch to loosen it up. You just tap on the collar ribs to get it turning in the right direction.
Rep Power: 276 Re: need help replacing fuel tank 2004 civic
explosion ftl.
if he post again will determin if he was successful, if not then he died a horrible firey death
If need be use those small propane torches to get the undercarriage screws loose lolllll
KABOOOOMMMMMM
KABOOOOMMMMMM
1 Post
Rep Power: 267 Re: need help replacing fuel tank 2004 civic
Set up a webcam so we can watch you loosen your bolts with a torch.... for educational purposes of course
McD
04-22-2015 05:28 PM
chgofirefighter
04-18-2015 08:08 PM
thesushiboy
04-12-2015 02:54 AM
