F/S - RSX Front Sway Bar - 23 mm x 2.8 mm
Old Aug 24, 2007
paulkramer's Avatar
paulkramer is on a distinguished road
Just removed from my '02 RSX with ~ 64K miles on it.
Fine condition, OEM bar. Replaced it with a different size bar - finally...
No endlinks or bushings, as the bushings were shot and the endlinks had to be cut off.
Will fit EM2 Civic, at least, as I installed an EM2 bar in its stead.
The "hoop" portion is more exactly shaped like a hoop on the RSX bar compared to the EM2 bar - don't know if that presents any clearance issues or not for installation on a Civic.
Old Aug 27, 2007
paulkramer's Avatar
Re: F/S - RSX Front Sway Bar - 23 mm x 2.8 mm
Bump
Old Aug 30, 2007
paulkramer's Avatar
Bump
Old Aug 31, 2007
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
i hear a lot of rsx guys run the em2 front sway to clear a larger header...sweet
Old Sep 2, 2007
paulkramer's Avatar
Not sure.....sitting here trying to visualize the EM2 bar's shape, but already the memory of the bar's shape is fading.....
I DO recall, however, that the EM2 bar is frighteningly close to my fuel lines - for some reason, that side of the bar doesn't curve back down as soon as the DC5 bar. I pushed the fuel line bracket as far away as possible.......
I bought the EM2 front bar for less understeer/improved balance. I'm running the EM2 front bar along with a solid 22 mm rear bar, H&R Sport springs and Konis. All season Michelin Exaltos, unfortunately.
Old Sep 7, 2007
paulkramer's Avatar
Bump
Old Sep 15, 2007
paulkramer's Avatar
Guess this is not as popular with Civic owners as an OEM RSX rear sway......
Bump anyway.
Old Sep 15, 2007
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
so your saying the em2 front bar provides less understeer than an rsx-s sway bar? how come that sounds funny?
Old Sep 16, 2007
paulkramer's Avatar
I know, it still sounds funny to me too.
And I don't think I can explain it adequately to you myself. If you want a good explanation, try searching for it on clubrsx.com, especially the posts by Zzyzx. Or pick up a copy of Caroll Smith's "Tune to Win".
But in short, most OEM setups are biased towards understeer, so the average joe driver doesn't get into trouble and swing his/her rear end out. Especially with a front-driver, where the tendency in such a situation would be to get off the gas, which would only exacerbate the situation.
And understeer/oversteer balance has a lot to do with the relative stiffness between front and rear, not overall stiffness.
I've reduced my front bar from the 23 mm OEM (hollow, I'm pretty sure) to the 15.9 mm hollow of the EM2, and increased my rear sway from the 19 mm hollow OEM to 22 mm solid (Comptech).
All I can say is, I should have gone with the 25 mm rear Comptech!
I started with the 22 rear. I was afraid I'd be oversteering all the time. That never happened, so I swapped out the front for the smaller EM2 bar. Still have yet to break my rear end loose, but the car is definitely much better balanced, and I can more readily modulate my turning with throttle only.
Old Sep 17, 2007
TRIZ's Avatar
^ rep for a good post- way to be a good forum guy!
Old Sep 17, 2007
paulkramer's Avatar
Sure, thanks for the rep!
Glad I could semi-explain something to somebody!
Old Nov 24, 2007
paulkramer's Avatar
Bump
Makeice3498
Jul 2, 2015 11:13 AM
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
