1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1985 1.3L overheating Need help!
Old Aug 16, 2007
Johnnyirsh's Avatar
Johnnyirsh is an unknown quantity at this point
Question 1985 1.3L overheating Need help!
I just recently purchased a 1985 Honda Civic HB with a 1.3l engine. The car has 105,000 original miles. Yesterday the engine started overheating. I changed the thermostat and flushed the radiator. I'm still overheating. Any suggestions?
This is my first Honda.
Thanks for the help,
John
Old Dec 19, 2007
badpenny's Avatar
badpenny is an unknown quantity at this point
Re: 1985 1.3L overheating Need help!
waterpump. and while you are pulling it, get a new timing belt and adjustment pulley.
Old Apr 4, 2008
MaximumMax's Avatar
MaximumMax is an unknown quantity at this point
well my gf and i had the same problem as badpenny knows and it was a very simple fix and i am beginning to think this is a regular thing with this engine.When you replaced the thermostat and filled it up again it is showing in the rad that it is full but this engine air locks because of the config of the neck of the rad..what we did was remove the hose from the heater core that goes back to the block and back fill the block .Hold the hose up high and fill till the antifreeze come out the heater core from the tube of the hose you just took off when it come outs the heater core then put your hose back on and try running it now
Old Apr 4, 2008
MaximumMax's Avatar
i wanted to add that we replaced our waterpump and it was still overheating and this is what we determined after that. So for the sake of alot of work i would try fill the block this way .
solarpunk70
Apr 12, 2016 11:43 AM
ken4444
Sep 30, 2015 07:37 PM
raymondxcho
Sep 29, 2015 09:00 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
